2013 Fiesta Advice
I’m upside down on my loan and want to trade in for a better vehicle at this point. However, haven’t driven it in a few months and now it won’t start ?dead battery, past due for inspection, and won’t pass due to a headlight issue... also needs new tires from sitting too long. Worth fixing up to trade? Is there a dealer that would let me tow it in for trade? It has about 95,000 miles on it. Transmission has been replaced twice under warranty and new brakes and rotors recently.
Answers
Realize too, that how much you're upside down is probably going to limit how much of a "better" vehicle you may qualify for.
But I'd start with figuring out what the car might be worth in a trade and weigh that against what it will cost to get it to where some dealer might think it's worth their while to offer anything close to what you think the trade might be worth.
if the car has been sitting, does this mean you just don't need to replace it? if so, can try to sell as is (off craigslist, etc.) but you won't get much. dealer will only take it if you are buying something to replace it.
normally getting it running at minimum is required to sell for more than scrap. So a battery and cheap tires (heck, you can get used ones, or the super cheap specials from the tire store) should have a positive ROI. Do the headlights not work at all? That sounds odd, but you really can't sell a car without them (at least, probably shouldn't, and at minimum, need to disclose and take the big hit).
it is probably worth a few hundred $ to a dealer as is, as a courtesy trade. Put the minimum you can to get it running and lighting, and should be a pretty easy sell privately for a few K.
The issues you note seem minor in terms of cost and convenience. Sounds like the car runs just fine, so having it in such condition is better than not. Age-wise, I really doubt there are serious issues with the tires, unless you have a flat and it's sitting on the rim, etc.
I would put it back to right, sell it privately, and enjoy a car-free life for a bit before you plunge back into the fray.
My Escape is turning ten years old and just passed the 320K mark....
https://forums.edmunds.com/discussion/44956/ford/escape/the-200k-club#latest
