Power steering
BigD1101BigD1101 Member Posts: 1
edited June 2019 in Dodge
Hey guys, looking for some answers on my dodge 2500 power steering. Pump is making slight whining noise, oil is foaming. Steering is bit harder than normal. Issue began with sudden onset. Replaced pump and still having same issues. No leaks or any obvious issues. Any ideas???????
  • rickdonrickdon Member Posts: 123
    Try checking the rack and damper also.
  • thecardoc3thecardoc3 Member Posts: 5,853
    Sometimes air gets trapped in the fluid. In the shop we can attach a vacuum source to the pump and help purge the air.
