not starting
i have a 2001 mazda protege 1.6l it was hard to start, meaning it would take forever cranking it over to get it to start so i have repalced the spark plugs, wire,coil packs, camshaft sensor, mass air flow sensor, fuel pump, throtle body position sensor, the egr valve, timing belt os perfect, i evern ran a compression test its perfect and it is still not starting
