Help finding fuse
OchalpenoOchalpeno Member Posts: 1
edited July 2019 in Lincoln
I have a 01 ls v6, I have been told to check for the dccv fuse before replacing the valve itself. I have the original owners manual and I cannot find any fuse for the dccv. Anyone know where it's at? My problem is hot air blowing through the vents when ac is on at 60°
Answers
  • stickguystickguy Member Posts: 54,163
    can you pop the fusebox cover and look at the diagram to see if that tells you?
