I have a 2002 Chevy tracker 2.0 and my a/c fuse under the hood keeps blowing and my a/c won’t work
KelkoKelko Member Posts: 1
edited August 2019 in Chevrolet
A/C fuse keeps blowing on my 2002 Chevy Tracker
Answers
  • thecardoc3thecardoc3 Member Posts: 5,862
    edited August 2019
    You didn't specify which fuse. Is it the 25amp fuse for the AC compressor clutch? Does the fuse blow immeadiately when you try to turn on the AC? Try disconnecting the AC clutch and see if the fuse still blows. If it doesn't then you may have a shorted clutch coil on the compressor.
