1989 325ix front window switch
cdavant3cdavant3 Member Posts: 1
edited August 2019 in BMW
325ix 1989 4 door 5 speed had a problem with the driver's side fromt power window switch. Worked only intermittantly. Other windows fine. Ordered replacement and installed yesterday. Now front and rear driver's side windows work normally, but neither passenger side windows will work. Is there some type of master switch I should have used? Fuses are fine.
Answers
  • Given the age of the vehicle, do you think it's possible that replacing the one switch jostled switches/moved wiring and broke power connections?
