2005 ford escape , sometimes it wont start, ford garage replaced computer , 1300 . did not fix
herrod67herrod67 Member Posts: 2
edited September 2019 in Ford
donnell ford replaced computer , lights come on on dash. but nothing else. replaced park, neutral transmisssion switch but to no avail. starts sometimes for days , then nothing again . can not trust vehicle THANKS HERROD67
Answers
  • thecardoc3thecardoc3 Member Posts: 5,848
    Is the theft warning light flashing when it won't start? Are there any codes in any of the modules? How long does it take for the car to be able to be started when the problem occurs?
  • herrod67herrod67 Member Posts: 2
    edited October 2019
    @thecardoc3
    yes the theft warning light flashes. dont have any way to checkthe codes. may sit for quite a long time , maybe a day before it will turnover and start
    Have you talked to the Donnell to let them know that the issue wasn't solved? See if they documented the codes when they initially attempted to figure this out. If so, try and get me what codes they found and specifically what module they were found in.
