Sluggish acceleration
I have a 98 Honda Passport. When it’s in drive and I take off from a stop, it’s very sluggish. 0-30 is about 30 seconds. When I put it in low and go through the gears manually, everything seems fine. I‘m trying to make sure I spend the right money to fix it but not sure where to start. Any help is greatly appreciated.
thank you.
thank you.
Back then the Honda Passport was a rebadged Isuzu Rodeo
You'll probably find help on some of the Isuzu internet forums cause a lot of southwestern and california owners still have interest in keeping their Isuzu No-Salt trucks going. Honda owners sent them to junkyards*
Let us know what you find out.
Any resolution to the problem drivetrain?
What you describe above about it going into failsafe, and then a key cycle restores operation is a classic description of an intermittent issue. Testing that a tech would need to perform would be to monitor the circuit that the computer is seeing fail. I would capture supply power, command side and the current flowing in the circuit simultaneously. Combine that with knowing what gear was commanded when the system faulted and then go back 250 ms (1/4 second) and see what happened. Then reset the testing as required if necessary. If you tell me what code(s) are setting I could explain this in more detail.
Another thing I notied that I think is related is it's getting TERRIBLE gas mileage. I just took it on the freeway and it seemed to be doing good, nothing that alarmed me with the transmission. RPMs hovered around 2,200-2,500 at 70 mph. but I was getting about 12 mpg.
