why does fuse 23, transmission, 10 amp, keep blowing and leaving me stuck in 3rd gear? 2008 Equinox
Chevy Equinox, 2008. Hard to take off in 3rd.
Best Answers
thecardoc3
Member Posts: 5,876
You didn't specify which engine/trans combination, (3.4l Vin F?) but I might have found the correct system schematic anyway. Looking at the schematic this fuse delivers power to the transmission control module on pin 11 (pink) and is labeled the ignition input. The transmission control module outputs this power to all eight shift control solenoids. It's noteable that it also controls the ground circuit for three of those. Wiring damage either internal or external of the transmission could be in play. A solenoid issue cannot be totally ruled out without testing which would be done by commanding the solenoids on/off and measuring how much current is flowing. If I was going to take this in and analyze the issue I would start by asking some questions about when and how often the fuse fails. Those first questions would be:
Does the fuse fail immediately or does it last for a while? If it lasts for a while how long in time/mileage?
When the fuse fails, does it seem to happen when the vehicle is in one particular gear or a combination of gears?
What about how fast is the car going when it happens?
Is there anything else that you can think of that would amount to a pattern or set of circumstances where the fuse is likely to fail? aka Hard acceleration? Light acceleration? Turns? Braking?
One thing a tech should not do is just open the transmission up and just look for a possible sign of trouble. The current is going too high when the fuse fails protecting the system. This can be measured and from there the individual circuit that has the problem identified and then ultimately the exact location can be proven and dealt with.6 -
Fuzzyyyy
Member Posts: 4
I understand the procedure, just don't have the tools. was sonar tech in Navy and studied electronics. Makes perfect sense and is detailed enough to make it seem easy. I couldn't have figured it out but I can follow the explanation.0
Answers
I would pull the fuse and install a "fuse buddy". This separates the fuse from the fuse block and allows me to put a low amps current probe on one of the wires and measure the current flowing in the circuit to the module on my PICOSCOPE. Then I am going to take three more probes and connect them to the various output wires from the module to the transmission. The wires would be grouped through the various probes so that depending on which probe(s) I see the current spiking I would be able to figure out exaclty which circuit has the failure.
For example there are eight solenoids that get power. I would number the circuits on the schematic 1-8.
Now for the current probes. Channels A, B, C, and D, on the scope.
Channel A will be the fuse buddy.
Channel B circuits 1,4,6,7
Channel C circuits 2,4,5,8
Channel D circuits 3,5,6,
Channels 7 and 8 would have the wires pulled loose enough from the harness to route them through the current probes in the opposite direction. That way they make a spike going downward when current flows in them.
If you look at that logic table a short ocurring on wire number 4 would give me spikes on channels A, B and C.
Now all I need to do is drive the car and monitor how much current is flowing in each circuit. The fuse doesn't even have to blow because I will be looking for spikes in the current that exceed the fuses rating but for too short of a time to cause it to fail. Once I know exactly which circuit is affected, then I can modify this and place probes at different sections of that circuit and narrow down the location.
