electrical problems
photo_op4u2photo_op4u2 Member Posts: 1
edited December 2019 in Mazda
i have replaced the starter, new battery, new ignition switch, still having problems, now it want crank, i bought it used, had a engine put in , engine runs fine, but electrical issue, any recoomendations?
  • inez_lynne01inez_lynne01 Member Posts: 1
    2008 Navigator. Battery checked...good. Alternator checked....good. Runs perfect until I shut it off and let it sit. It will not start until I jump it or charge it for a couple of minutes. Starts immediately and runs perfect until I shut i off again. Suspect Power Relay or maybe called Ignition Relay. Any advice?
  • RicardowelchRicardowelch Member Posts: 15
    2008 Navigator. Battery checked...good. Alternator checked....good. Runs perfect until I shut it off and let it sit. It will not start until I jump it or charge it for a couple of minutes. Starts immediately and runs perfect until I shut i off again. You want to know when to replace car battery, just visit AutoGuysLand for more info. Suspect Power Relay or maybe called Ignition Relay. Any advice?
    Have you tried to check the connection if it is loose or not. also this problem can also be indicative of solenoid problems.
