04 Camry Power Seat Fuse and Switch
Hello, I have a puzzle, for me. How do I remove the 30 AMP square fuse under the dash? See Attached. And... Anyone splice the ten wire harness to the Power Steering switch?
My Power Seat forward/back function stopped working awhile back but other switches worked. It would Only move forward. I accessed the switch and ten wire plug and wrapped a rubber-band to hold the switch in the back position. I then jumped the two wires and was able to move the seat back to a position that all drivers could use. A few months later a driver forgot, and moved the seat forward. Now difficult for me. I then tried jumping the wires again but this time generated a spark and one of the wires burned some.. I think I used to small of a Gage jump wire. Now, No functions work.
I went to the JY and pulled the same switch and plug with about six inches of extra wire.
How do I remove the 30 AMP fuse under the dash? Trick? Tool? Anyone have experience splicing the ten wire harness to the Power Steering switch?
