Antenna
PhiluPhilu Member Posts: 1
edited February 2020 in Volvo
Does anyone know where the antenna is.
  • qbrozenqbrozen Member Posts: 29,105
    in a 2005 S40? It sticks out the rear driver's fender. You can access it from the trunk if it needs repair.
    ‘21 Camaro LT1, '07 ML63, '08 Charger R/T Daytona; '67 Coronet R/T; '13 Fiat 500c, '14 Town&Country Limited. 54-car history and counting!
    ah, wait, that may be wrong. I found a replacement power antenna that claimed it fit up to 2005. If you don't have such an item on your car, then it is in the rear window. Here is an interesting manual someone wrote that describes where you can find the various components. https://docs.google.com/viewer?url=http://volvo.philipfotos.com/English_install_ver_6_5.pdf
