Car engine fades off and then fades back in when started when engine is warm
Whenever I start my car when the engine is warmed up, it'll crank like normal
and the starter will work fine and you'll hear the combustion. But, the sound
immediately fades away and it sounds like it just died, but then it will quickly
fade back up and sound normal again. Sometimes, it will just die and I have
to start the car again. When the engine is warm, I give it some gas on the
throttle to make sure it doesn't fade out like it does when I don't give it gas.
I've had someone tell me it could be a bad sensor, a bad starter, bad fuel
injectors, etc. I have a video of how it sounds to show what I'm talking about,
but obviously i can't attach it here.
Could be so many things from crankshaft position sensor, to coolant temperature sensor, to oh so many things.
It'll save money spent hanging parts from guessing to find a good mechanic and pay for the analysis.
BUT that was a problem that can be verified by watching the fuel mixture adjustments the computer was making as the oxygen sensors were getting symptoms of a lean mixture and trying to compensate.
Again, before hanging any more parts, you need to verify that that part is the problem. A scanner like mine that's several years old can follow the fuel mixture adjustment. Find someone that can use their scanner to look for the symptoms and look for the actual cause.
Disconnecting the MAF or MAP is often tried as a test to decide if they are the problem. Could be. The MAF can be cleaned with a spray cleaner and a camel hair artists brush to light clean particles that stick to the wires.
BUT disconnecting them can affect other things and that will seem to cure problems. A friend and our shadetree mechanic neighbor found that his MonteCarlo with the 32 valve engine would improve if MAP was disconnected. But that wasn't the problem Took a transmission guy using his scanner to determine what it was.
Find a professional shop to at least diagnose or find a good shadetree mechanic with a full scan ability that KNOWS what they are looking at.
Maintenance done:
-Cleaned MAF sensor
-Cleaned throttle body
-New air filter
-Spark plugs changed to iridium a year ago
Possible reasons for issue:
-The car muffler isn't stock (straight through muffler)
-The car sometimes has a funky smell after turned off after being warm
-The car pops when revved after warmed up
-It takes just a bit on the throttle right after the starter successfully turns over to get it running
Belief:
-Due to the muffler not being stock and it being a straight through muffler, it could be causing a lean A/F mixture that the car does not adjust to, which would explain the exhaust popping when the engine is warmed up on revving.
-Too much fuel going into the engine after it is warmed up could cause the engine to be flooded, which is why starting it some time after it sits is unsuccessful and letting the excess fuel into the exhaust which causes it to pop
-Bad fuel pump
-Bad fuel injectors
Maintenance done:
-Cleaned MAF sensor
-New air filter
Belief:
-Too much fuel going into the engine after it is warmed up could cause the engine to be flooded, which is why starting the car is unsuccessful after is sits while warm
-The funky smell could be unburnt fuel sitting in the engine/exhaust slowly being burnt by the heat of the engine and/or exhaust
-Bad fuel pump
-Bad fuel injectors
