Reprogrammer
Hello. I have a question. I am thinking of getting a programmer to flash our 2007 Ford Escape hybrid. Do you have any recommendations of what & where to get one? I live in Ontario Canada. The car will not start. No crank..That is after installing another transmission into the car from the auto wreckers.
https://www.motorcraftservice.com/Home/Index
Check and make sure that your computer meets the minimum requirements.
Since you are going to work on a Ford, your first choice for a pass through device would be the VCM 2.
https://www.motorcraftservice.com/diagnostic/Support?channelId=37&categoryId=280
If you work on a lot of different makes and models then the DrewTech Cardac M MegaCan would be a valid choice. http://www.drewtech.com/technician/products/cardaqm.html
Now you can choose the subscription. The FJDS is the flash programming software. IDS is both Diagnostic and Flashing software.
https://www.motorcraftservice.com/diagnostic/Support?channelId=46&categoryId=286
