My Key won't Turn?
Jerry_MaxineJerry_Maxine Member Posts: 1
edited June 2020 in Toyota
tried to replace my transfer case but ended up having to put it back together My car will not allow me to turn the key to ignition/start. The steering wheel won’t lock lock or completely unlock so I can turn the key. Also I heard bloop bloop bloop noises coming from engine bay and Joe the acceleration pedal makes clicking sound has barely any tension here is how it sounds
https://youtu.be/gYpFNHNlQTI
None of these things were happening before I messed with the transfer case. Only happened once last time I was in same situation but eventually worked again
Answers
  • xwesxxwesx Member Posts: 17,923
    Eech. What is the vehicle? Are you sure all of your mechanical connections are put back together, including the shift interlock on the transmission? That sound make me think there is a connecting arm just flopping around in your engine bay....
