PLEASE HELP ALL CODES FOR MY PASSAT
oliverp72oliverp72 Member Posts: 1
edited July 2020 in Volkswagen
So i'm making this forum because I want to fix everything wrong with my 2005 volkswagen passat. It would also help if you let me know which of these codes I need to fix and the priority each code would be and what order I should fix each code in. Please leave a comment if you know how to fix any of the issues with my car. Thank you.
CODES:
17881 Active/Static Leak diagnosis pump - EVAP emission ctrl system,Open circuit-No signal/communication.
17833 Active/Static Evaporative Emission (EVAP) Canister Purge Regulator Valve -N80,Short circuit to ground-Lower limit not reached.
17955 Active/Static Wastegate bypass regulator valve- N75, Shortcircuit to ground- Lower limit not reached.
17525 Active/Static Bank1-Sensor2, heater Circuit, Short circuit to ground-Lower limit not reached.
17843 Active/Static Secondary Air Injection Pump Relay-J299,Short circuit to ground-Lower limit not reached.
17829 Active/Static Secondary air inlet valve-N112,Short circuit to ground-Lower limit not reached
17697 Active/Static Turbocharger recirculation valve - N249,Short circuit to ground-Lower limit not reached
17523 Active/Static Bank1-Sensor1, Heater Circuit,Short circuit to ground-Lower limit not reached.
18265 Active/Static Load Signal,Error Message from Engine CM-mechanical malfunction
01336 Passive/Sporadic Combination Comfort databus-Faulty
01330 Passive/Sporadic Central control module for convenience system -J393- No communication
01304 Passive/Sporadic Radio-No communication
01331 Passive/Sporadic Door control module on driver side -J386-No communication
01332 Active/Static Door control module on passenger side -J387-No communication
01333 Passive/Sporadic Left rear door control module -J388-No communcation
01334 Passive/Sporadic Right rear door control module -J389-No communication
  • thecardoc3thecardoc3 Member Posts: 5,863
    edited July 2020
    Concentrate on the "Active" codes, don't worry about the "Passive/Sporadic" ones at this time. Have you checked fuses? Specifically fuse # 34 for power to and through it?
  • Mike_SiegalMike_Siegal Member Posts: 3
    edited December 2021
    Man...that's quite a List.
    • WHICH CODE Reader did you use ?
  • BelAlliBelAlli Member Posts: 11
    CODES:
    First of all clear all fault codes and then drive 10 miles and reread errors.
