Replacing a RIM Module on a 2002 Deville
Zergkiller1Zergkiller1 Member Posts: 2
edited September 2020 in Cadillac
Howdy.
I was wondering if anyone here had ever replace the Rear Integration Module on a 2000-2005 series Cadillac Deville. Should it be just plug and play or does it have to be programmed to work?
Thanks in advance.
Best Answer
  • thecardoc3thecardoc3 Member Posts: 5,861
    Answer ✓
    The RIM is usually plug and play but there are some options the vehicle could be built with that make it programable.
Answers
  • Zergkiller1Zergkiller1 Member Posts: 2
    Thanks so much for the response. I've heard from South Main Auto on the internet, and on a Buick, that the automatic load leveling system could require reprogramming, but I'll get to that later. Unless you want to respond???
    I have a "base" Cadillac.
