Dodge Dakota: Problems & Solutions
From my photo, you can see that I used a few TyWraps on the pipe insulation just tight enough to hold it in place. I have been meaning to make a cardboard "template" for the top of the "aluminum can on the firewall" then cut some of the stick-on tape to make a custom-fitting insulating cover.
Although I was initially skeptical that the stick-on insulating tape would actually stay in place, After about 18 months, there are no indications of peeling.
Are pictures of your mod posted on any site? If they are not, please e-mail them to me.
Drive Safe,
Joe
Go up to append #1695. I put a link there several days ago.
If you have problems with that link, I can email the photo to you directly.... let me know.
Drive Safe,
Joe
The other rubber coupler also came with the clamps.
The aluminum-looking straight piece is actually a section of 3" PVC schedule40 pipe. I smoothed all the inside edges of the ends for improved airflow. I then lightly sanded with fine grit sandpaper and gave it several VERY light coats of silver (aluminium) spraypaint. It looks like brushed aluminum as you can see in the photo.
(I allready had the section of pipe and spraypaint from other projects around the house.)
Now, I am considering somting like this next;
http://www.airaid.com/300-117.shtml
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
On the Dakota, the front brakes are KNOWN to be a weak spot on an otherwise great truck. Many of us (including myself) have replaced the front brake rotors with POWERSLOT rotors from a group-buy. I also went with the ceramic-based pads from RAYBESTOS.
I am very pleased with this combonation which has noticibly improved the braking performance of my Dakota as well as the brake pedal feel.
I, too expect my 2000 Dakota to go for at least 12 years and 150,000 miles.
I've got some conflicting information.
Thanks!!
Blue
Dick
In Atlanta
Hmmmm! I thought that it was supposed to be filled to 5/8 of an inch below the fill hole. Any ideas?
Blue
FYI, I took the cover off and cleaned it real good. got all the shavings and such out, so it was completely (bone) dry. Oh well, up to the plug and I'm done with it.
Thanks for your help.
Blue
Started doing your AC mod to my Quad. I bought the foil sticky insulation (comes in plastic bag, made by Frost King, $5) and a length of 3/8 pipe insulation, $1. Got the 'can' done (even the bottom) and the 2 pipes from it. The one from the firewall and the last one is from the compressor in front of the engine, as seen in the picture right? None of the ones way out in front then, from the dryer I think. Not positive all the components in the system. Thanks, seems to work better, I was only getting the real cold air when I was on MAX but now normal seems better.
Eric
You would actually reduce the effencency of the AC if you insulated the HI-pressure side of the system. This is from the TOP pipe out of the compresser - into the 'small radiator' and out the other side of it. From there, it goes into a flexable rubber section of pipe. After that flexable section, you should insulate the solid piping all the way into the firewall. This is the beginning of the "low pressure" part of the system and is where the cold is 'created'.
I have had the oppertunity in the past couple days to use my AC (95degrees 95%+ humidity). It gets so cold that I have to actually turn up the heat a notch or 2. This is MUCH better than before I installed this 'mod' to my AC system.
Unless the dealer is going to give you new pads and rotors for free (as if it occurred prior to 12,000 mi) I would take bpeebles advise and blow off Dodge. Put good, aftermarket rotors and pads on and be done with it. I've been getting mine changed every 9000 mi, (free) but have a set of new Raybestos rotors on deck when Dodge says enough!
Otherwise smooth quiet steady ride and NO COMPLAINTS... still a very happy QC pilot.. there! I checked in.. ;-)
Sorry for the late reply, I went down to tennessee for a family reunion this holiday weekend.
I do have the trac-loc rear end.
FYI, the trip was very uneventful. Which is a good thing. I averaged just about 19 mpg on the way down (470 miles) with AC on the whole way, which is pretty good for me. I have a pretty heavy foot. Didn't get that on the way back as I really wanted to get home! lol!
Rear end performed flawlessly. No whine or noise, and seems to be less noise when I put it in drive and it takes up some slack. Maybe thats the RP working like advertised.
Just to let everybody know, when i pulled the cover and got the shavings out, there was a piece of metal the size of a staple (a thick staple) sitting in the bottom. Seems kind of odd, but the rear diff has never given me any problems with noise or slippage.
Blue
They confirmed it was part of the carrier and ordered parts ( carrier). Went to reassemble and said housing was damaged. 1-1/2 weeks later it is ready.Plus side- the clunking during changing gears ( auto) seems to subsided. Minus side- A howelling sound when coasting and housing darn near burns to the touch.
Cannot wait to see what they say now. Seems I've heard about other hot to the touch issues. This was the case before also, but seams worse now. Anyone else have any problems?
Also, would anyone be kind enough to tell where to get the shop manual again?Thanks
Blue, might want to keep an eye on yours.
Bpeebles, could this be caused by inproper gear set up?
(When you COMPRESS a gas, it gets hot.... when you uncompress it, the heat is released.(cold))
If you have any doubts about where the low-pressure (cold) part of the system starts, Just run the AC for awhile then turn off the engine and carefully feel the pipes with your hands... It will be VERY obvious which are the "cold" pipes that should be insulated.
Dick
slr9589
Well I had 5000 miles on my 2002 Quad Cab and decided to rotate the tires.
Been a while since I last rotated my own tires. Had my last vehicle, a Cherokee, for 140,000 miles and 13 yrs, replaced the stock tires right off the bat, and always had free rotation with the new tires I've bought.
But since I'm cheap and I've read all the posts about how overtorqued lugnuts can contribute to warped rotors, I've taken to doing my own again.
Anyway, everything was going fine until I went to jack up the right rear axle. The saddle on my 3 ton jack is too big to fit anywhere on the right rear axle. So I was thinking about jacking on the pumpkin, used to do this all the time, but I have heard some bad stories about damage to the pumpkin/axle on the newer Cherokees from jacking, and didn't know if they were using the same rear end in the Dakota. So I played it safe and finally just used the jack that came with the truck.
Anyone else have this problem? Where did you put your jack?
Don
I always loosen the lug nuts just before "getting air" under the tire on the way up since "rocking" a car off of the jack trying to loosen lug nuts put on by an air-wrench. On the way down, I tighten them the best I can, then set the tire "lightly" on the ground before the final torguing.
Still, answer me this......why is there no "recirculating air" feature on this truck. My friend with a 96 Cherokee doesn't have it either. The vents/air cond suck in all the evil pollution that is in front. Only way around is to shut off the vent entirely.
Not a big deal until I get behind a diesel, crap car smoking, or run thru a skunk.....and I've done all 3.
Does anybody else's sound like this?
Drive Safe,
Joe
WARNING - It appears that the best solution would be to completely remove the sway bar and lube the inside rubber surfaces and then reassemble. During my short-cut procedure, I was always concerned that the "loaded" sway bar would cut lose and either hurt me or be significantly out of position for easy reassembly. Be careful.
My next project will be to modify those two frame brackets by tapping in grease fittings. I plan to drill a hole through the rubber to connect to a system of groves I'll cut into the rubber at the rubber / sway bar interface. This should allow for frequent and easy lubing at the right spot. BTW, I got this final idea from an Energy Suspension advertisement. Their urethane components are designed with this grease fitting system.
I saw the same ad in "truckin" magazine. Those ureathane bushings have a groove around the inside-center to distribute the lube.
A couple of questions;
1)Are you going to use a rubber lube that does not attack and disentagrate the rubber bushings.
2) Have you tried lifting both front wheels off the ground? (put a jackstand under each of the the framerails) This may "unload" the swaybar sufficnetly to pull things apart without harm.
With 35K miles on my 2000 Dak, the original rear shocks were shot. There was a coating of oil on them that had been leaking out for some time now.
I installed Edelbrock Performer IAS (monotube) shock abserbers on my Dakota. The difference is noticable.
I first installed the rears since is is so easy to slide under the back of the truck and do it.
I went on a 200 Mile trip with just the Edelbrocks on the rear and I could not detect any "hopping" to one side. During accelleration, the rear wheels stayed in contact with the road instead of "hopping" all over the road as they were with the old shocks.
Today, I install the FRONT Edelbrocks. This really made a difference. There is virtually no "nose dive" when I hit the brakes and sharp turns are very flat. (no body lean)
I went out on some bumpy dirt roads and I cannot even FEEL the washboard on the road. The IAS really lives up to its desert-racing heritage.
In regards to cutting grooves into the rubber, I would suggest against it. The durometer (hardness) of the rubber is low to begin with, and cutting it would weaken it even more. I have not priced the urethane bushings for this application specifically, but in the past, it seems that the price is reasonable enough to get the new ones and install them with lube. The urethane needs less attention over time then rubber as well. There are also brands out there that have graphite impregnated in the urethane to lessen the need for lube even more.
John
bpeebles & tuvtest - It was weird, one side (passenger) of the bar stayed up and in contact with the lower "A" arm while I loosened that side's "U" bracket. At the same time, the driver side of the bar constantly pushed down on the "U" bracket with enough pressure that I didn't want to complete untread the bolts. This work was done with the truck sitting level in the driveway - no jacks.
Maybe there isn't a loading problem and I just chickened out. I don't have jack stands, etc. so if I get into trouble, I'm screwed. I got the results I wanted without too much trouble.
A while ago, I checked out the Energy Suspension website and they didn't have the entire set for Dak's. So absent that, I have no problem drilling a single hole through the OEM rubber and cutting in a single groove to distribute the lube to make sure that the dreaded "pops" stay away.
I would forgo the grooved bushing. If a ureathane bushing is not available I would purchase 2 new bushings from Dodge and install them with white lithium grease applied to the contact surface. I suspect the grease will last the lifetime of the truck. Just like everything else here this is just my opinion. regards, Rick
Front = E3323DAL
Rear = E3423DAK
I did a LOT of research on shock absorbers and ended up with the Edelbrock IAS (monotube) shock.
They offer the IAS in a twin-tube design that costs less but this is considerd a 'toy' compared to the real monotube design.
Since the prices for the Edelbrocks seems to be the same within a few dollars everywhere I looked, I ended up ordering from a place that had lower shipping costs for me. ( www.shockwarehouse.com )
Since I installed the rears within an hour of taking the packlage from the UPS guys hands... then the fronts on another day, I did not even break a sweat installing them. I took my time and would say I took no more than a couple hours on each pair. (I was enjoying the quality time with my Dak ;-)
Removing the oid shocks perhaps took most of the time. (those bolts were TIGHT) I, of course, used my new torque wrench to install all bolts per the factory service manual specs.
John
- Drive without touching brakes for at least 20 minutes.
- Come to stop WITHOUT TOUCHING BRAKES
get out at carefully feel the lugnuts and wheels for "heat"Also carefully feel the brake rotors for heat.
Check the brake caliper too.
Under "normal" conditions, the wheel, lugnuts and caliper should be no warmer than the body of the truck.
The brake rotors may be warm to slightly hot to the touch but you should NOT feel heat radaiting from them.
NOTE:
If your lugnuts/wheels are running hot to the touch, you may be needing front bearings soon because the dragging brakes have cooked the grease from them.
PS: This test is often best done on a highway with "rest areas" you can drive at 65 for a while and there is plenty of space to allow the vehicle to slow down as you approach a "rest area". Use the emergancy brake to come to a complete stop. (just the last few MPH) While holding the release lever out... the EMO brake can be treated like a normal brake pedal. This will only warm up the REAR brakes.
Yes, you used less than $5 worth of parts to do this. But consider the LABOR to install the insulation properly. Then multiply that by how many vehicles that come off the assembly line. you should start to see how the beancounters at the factory can mess up a GREAT design by saving a couple hundred thousand dollars.
