Dodge Dakota: Problems & Solutions
Any thoughts on this would be appreciated.
Don't know if that is your problem or not, but I had rather figured that myself though I did for matter of record want the dealer to research the perception.
I have never really taken a liking to antilock brakes, though they do seem to be a mainstay of current vehicles. One of those little things one learns to live with.
They have always been disconcerting to me when they apply.
I also have a 1998 dodge dakota sport and within the past few weeks I have been having a/c problems. So far I have found out that I have enough freon in the system. So that is not a problem. I found this out by buying a charge kit from wal mart for about 20 bucks. It has a guage that measures the amount when connected. This must only be done when the compressor is running though or it will be way off. Also I have found that my compressor has not been running as it should. After checking the relays in the fuse box which were okay, I think my compressor clutch is going bad, but when it works the air is cold, and when it doesnt the air is hot. Hope this helps... Got any ideas
thanks Imabaytiger
ashby
Just a heads up on the part while I am at it.I took the old sensor apart,it is just pressed in with the plastic case rolled over the insert to hold it in.It was like peeling a turnip,I used a small xacto knife to peel away the thin layer that held it together and it popped right up out of there,just another O ring holding it in the housing.
There are no active components inside,it is really pretty simple.It is an iron core with a powdered iron magnet surrounding it and a scazillion turns of magnet wire for a winding and the sensor is just a pickup that senses the changing field as the tone ring on the ring gear passes in close proximity to it as the truck is moving and sends that changing signal to the computer which interprets it as motion.
The new sensor measured 1818 ohms and the failed sensor was completely open at zero ohms so it is now possible to troubleshoot the sensor without removing it,saving yourself some money and embarrassment in the event you didn't need one after all.
As was spelled out before,a six point deepwell 13 and 15 mm socket and you may need a 15mm openend wrench in case the nut,bolt and eveything come out as one piece,a screwdriver to pry the old one out and some neversieze to paint the O ring and threads with and you can fix it right up. Ron G
Is this normal? What's going on? I knew the Dakota got bad ratings for brakes, but the pads going out this soon is ridiculous...if that is indeed the problem.
Thoughts?
A high pitched squeal usually indicates that the pad is vibrating at a high frequency as the pad surface contacts the rotor. Also usually it is the point at which the pad backing plate is contacting the rails that is the spot that causes the squeal. High humidity days can cause this, but if it's steady despite the weather than it is more than likely a lack of grease on the contact point, or the rotor is out of round.
Dusty
I have tried the "parking brake test" several times... it does not cause a squeel, This is because using the parking brake pivits the shoes differently than the hydrolics do.
Just get used to it...its a TRUCK!
Actually the brakes on my Dakota never squealed in 45,000 miles until the pads and rotors were replaced. Same thing on my last car, '93 Nissan Sentra, and our '99 Avalon. In fact, the Avalon squeals about as bad as any car I've ever owned.
The squealing is getting less frequent. If it doesn't stop completely in the next few hundred miles I'll take it back.
Bests,
Dusty
Despite your relatively low mileage, I'm going to guess that the pinging is either poor quality spark plug wires, cap, or rotor. If not, I think the intake manifold gasket is bad.
Good luck with your new ride.
Regards.,
Dusty
Bookitty
Best regards,
Dusty
Did the dealer mention this is a SAFETY issue?
There's only one reason to replace the lower control arm, and that is from damage. Being told that two need to be replaced is suspect.
Bushings are replaced independently and I believe they are even spared by Chrysler as a separate part. Now factory ball joints are spared with the control arm. Aftermarket joint assemblies, as I've already noted, are available as piece parts. I just had new upper ball joints replaced by Chrysler under warranty and they were installed as a separate unit.
Dusty
Do you still have the factory battery? If so, batteries that are entering their end-of-life zone appear to generate strange electrical problems on Dodge trucks.
Another possibility is an intermittent Central Timer Module (CTM).
Dusty
dataguru
Now my front-end "clunk," or I would say more appropriately a snap, turned out to be the upper right ball joint. Mrs. Dodge replaced both upper for me a week or so ago and now the front end is quiet and tight.
Bests,
Dusty
replace by dealer. Fixed my problem.
Glad to hear your rig is tracking tight and quiet again. Have you notice any signs of the shock absorbers going soft causing more body roll now than when new?
My '03 QC has a late May 2003 Build Date so the upper ball joint Recall does not apply according to the dealer. They reference an official list of VIN numbers to which the ball joint Recall applies. To alleviate the concerns of 2003 owners, DCX has extended the ball joints warranty for all 2003 owners not affected by the Recall to 10 years from Date of Purchase.
dataguru
I replaced the upper and lower ball joints this weekend with Moog parts. Boy, this thing rides GREAT now! However, while the lower control arms were out, I noticed the bushings were shot. Everywhere I've checked, no one sells replacement bushings; they aren't even cataloged anywhere. The dealer wants to replace the entire control arm ($585 for each #*$&^$#^% arm!). That's ridiculous! BTW, I didn't mention that the front end is torsion bar, not springs.
Is there any way to replace these bushings? I can't afford $1100+ in parts!
Karl
The problem with replacing the CTM is that this module is easily damaged by another electrical problem, such as a short to vehicle frame (ground), a bad input or output device, or intermittent electrical connections.
Best regards,
Dusty
What I have noticed, however, is bounce at certain speeds on certain types of pavement and a lot more suspension travel during some pavement undulations. This I'm pretty sure is because the shocks have softened up.
Do you have a suggestion for shock replacements?
Bests,
Dusty
With the normal wearing of OEM shocks, I notice the same conditions as you with the increase in the amount of bounce at all speeds and terrain.
With regards to shock replacements, I'm going with the Edelbrock IAS Performers; specific PNs, #33410 (Front), #34410 (Rear) for 2WD. For bushing replacements, I'm considering components from either Energy Suspension or Moog.
Cheers,
dataguru
Kent
Rear leaf springs on Dakotas seem to be pretty tough and long lasting. I can't remember ever hearing of one being replaced unless the Dak was ten years old and had lots of miles. I don't think A-arm bushings are going to affect lean. The factory bushings are of good OEM quality. They usually cause squeaks or something as they get older. A new bushing or stiffer replacement would probably improve handing, though.
Sway bar bushings on older Daks produced God-awful noises at times. Mine are the newer type and so far have been trouble free. These might affect body lean to a degree, but I'm not sure how much. If anything, front springs that have taken a set or been driven in a compressed state (hauling heavy loads) would more than likely affect body lean more. That applies to thew rear springs as well.
Have you checked the front sway bar to see if it's broken? If seen this happen...not on a Dakota...but that would make a big difference. Or, you could install a heavier sway bar.
Bests,
Dusty
