Dodge Dakota: Problems & Solutions
Now weather is cold and snow is on the ground. I cannot go out and start vehicle and let it warm up. It will not get warm unless I start to drive the vehicle and then it will warm up nicely. If I go into a store and leave the truck running, my temp gauge starts to go up and the warm/hot heater air will start to go cold. I think this indicates a flow problem but have no idea what else to do. Not sure what to do next except sell as I've sunk enough money into the truck. Thanks
Whereabouts is the thermostat located?
Well I'm going to look at getting it back-flushed first, then go from there.
How do I get the Spare Tire off the truck ... No owners manual ... and have a flat !!!! I see a turn handle infront of the tire but what do I use to lower it and where do I stick it !!!!
I see you never had any replies to your problem. I have the exact same problem with my 2001 Dakota Quad 4.7 Auto, and the dealer (Triangle Dodge in Graniteville, SC) has never been able to solve it yet. They've tried everything. Even a brand new PCM (computer), to the tune of $900.00, has not solved the problem. It has been one big troubleshooting adventure for the dealer, at the expense of my wallet. Now the Power Steering Pump sounds like it's fixing to take a dump.
Do yourself a favor, and trade it on a new Toyota Tundra Quad!
Butch in Aiken, SC
One day, I noticed that my temp gauge was a bit erratic - doing excursion to >220F then back down to a normal 190F. Later that evening, things got much worse and the gauge redlined @260F and I pulled it over immediately. Note that this came with no "warnings" such as a noise, etc. though I confess that I didn't check for leaks under engine (never sensed a problem before). At this point, however, the "weep hole" had opened up on the bottom of the water pump and most of you know the rest of the story. The coolant was rather rust-colored.
1) OK, I had the pump replaced and was advised NOT to flush the system now as things had rusted to the point that this may invite more problems, as leaks in the radiator or freeze plugs. I'd like to know if anyone has had this experience and agrees with this position?
2) I was also told that the condition of the coolant over time caused the pump bearing to fail. Any thoughts on this?
3) What is the relationship between a failed pump bearing and the "weep hole" deciding to open up and drain the coolant? I'm very curious about this.
4) Regarding the earlier cooling heating symptoms, I was told that the condition of the coolant over time did a job on the heater core, which I find believable. Is there any magic liquid I could add to the coolant that would help remove the "plaque/cholesterol" from the heater core to help restore it? Then maybe I could simply drain (remove case plug) and replenish the coolant at intervals to rid the gunk ...
5) As I had mentioned in an earlier post, I noticed (as have many other Dodge owners) the elusive "Check Engine" light come and go. I wonder if this could have been somehow related to the impending pump failure - either a sensor of the bearing state, coolant level (mine had probably been falling over time), or some other related variable? I checked the P-codes I have access to and did not see anything obvious.
I realize these are a lot of Qs, and I did research the data base on this forum before posting this. I did not see any similar Qs posted. If anyone could please entertain this, I'm sure we could all learn something.
DakotaMan
2. Yes, coolant also has a lubricant in it and in time will cause the pump to fail if not maintained.
3. See #2. Seals will fail of their own accord but slack in the bearings will take the seals out in a heartbeat.
4. Again, have the system professionally flushed if you don't have the equipment to properly back-flush it, this will also take care of the heater core.
5. Possibly related to the coolant level but doubtful.
As for (2), are you saying that the lubricant in my coolant eventually dimished, and that may have led to the bearing failure?
As for (5), it'll be interesting to see if my intermittent Check Engine light now goes away ...
I forgot to mention that my Dakota has only 57K miles on her.
I wonder if Dusty is still out there? Penny for his thoughts ...
*) Air trapped in the system
*) Thermostat problem
*) waterpump not pumping
*) Use of incorrect antifreeze that will "GELL" when mixed with HOAT antifreeze....thus plugging the system.
Seems like the wiper arm blade spring is very strong and
causes the new blades to deform while just sitting in the rest position. Then when it rains the blades start sqeaking in a few months,,,I've tried just about all the brands and they all do this. The blades on my 2005 Highlander are over a year old and are not squeaking!
Oh, well,,,,MERRY CHRISTMAS to all,,,,,,
P.S.
I've decide to buy Yokohama Geolander tires.
Mick
2001 QUAD, 2WD. 64k miles.
Water pumps should last more than 57K but it isn't unusual for one to fail at that mileage. I replaced the original water pump on my '93 Dak at 117K but I have replaced many others at a lot less mileage than that.
Basiclly;
**Natural rubber will "wipe" the best... but tends to degrade the fastest in sunlight. Also tends to deform faster when parked. (not being used)
**Synthetic rubber is tougher and can resist UV light... but does not "wipe" nearly as well.
(some are a composite of natural/synthetic... these tend to be a good compromize) I recommend BOSCH as perhaps the best wiper blades.
Since you have tried several different brands/types of wipers...lets take another approach at your problem.
First, make CERTAIN that the glass is squeeky-clean. You may have gotten some type of silicone or other oil on the glass which is VERY difficult to remove. (There are not many chemicals that will remove silicone from glass) I am guessing that you must have used some kind of wax containing silicone and it "bled" down on to the glass when it rained. Use plenty of muscle to scrub the glass and scrub in at least 2 different directions.
There is a little-known "adjustment" that can make a HUGE difference in wiper performance. The angle at which they contact the glass can be "tweaked" by slightly twisting the wiper-arm. This is most easilly done using a cresent-wrench clamped down on the arm near the wiper end and applying some "twist" in the desired direction.
Also, in reference to your comment on the wipers taking on a "set" while at rest.... I usually slide out the rubbers and re-install in the other direction to compensate for that phenomenon. I have been able to DOUBLE the useful life of wiper blades in this mannor.
Also, DO NOT get rid of the original wipers from your Dakota... if you look closely at them and count the number of "holders" for the rubbers, you will see that the originals are "special" because they have additional holders for the rubbers. (A very good measure of a windsheild-wiper quality is the number of holders for the rubbers....more is better)
Besides, it is better to replace JUST THE RUBBER and not the entire thing. It is a HUGE waste of money to replace a perfectly good part.
on the down stroke. I'll clean the windshield and replace the blades again. I've used Bosch blades with same result.
I'm still enjoying my 2001 Quad! It's a keeper for a few more years!!
30F outside. Start truck, turn on radio, drive 2 short blocks for a newspaper, shut off engine, go inside store.
Come out, start truck, have no radio, no blinkers, no heater blower fan on any low-med-high setting. Do not know if blower was working in that 2 block drive. Pull over, shut down, wait 10 secs, restart engine, same.. shut down everything. Check inside fuses, ok. Reseat fuses and relays in engine compartment elect box. Restart engine, radio, blinkers work. Blower fan still does not work on low-med-high/full settings. Wiggled blower resistor connector on ductwork. Same. I drove to work (45 mins) and heard clicking noises near ashtray sounding like a relay also. I searched the "blower resistor" posts, and many say resistor used for low/med settings, and one post said blower fan did not work at all.. looks like I may pull the resistor today and measure for any resistance, then head off to the dealer for a replacement resistor. Crap, and this is my last day at work to return my badge as I got layed off! Mr. Loser..
You are describing a different scenerio. Look for a blown fuse first.
ALso -- I am sorry for you getting layed off. It is hard to have a merry Christmas under those circomstances.
Or search on this forum.. seen this..http://autorepair.about.com/cs/troubleshooting/l/bl_obd_13.htm
I also saw this..
"P1391 Sometimes, I can't see the crank or cam sensor signal." I can't 100% confirm that this is your description of your error..again check on the web..
Good luck..
This was serious mismanagement. But I am determined to get the system flushed ASAP.
Stuck Now..any and all help greatly appreciated.
2001 quad,4.7l, 3.92lsd,5 speed. I still wonder what a slight clicking sound is of which comes from behind the heater controls area. Glad the blinkers and radio is still back working!Ger
PO152, R-UPSTRN O2S(2/1) Shorted high.
The truck was in for tranny flush and guy ran diagnostics when he saw chek engine light. 2001 club cab, 3,9 v6. Symptoms also include, loss of feul economy, jumping out of O/D, loss of pulling power.
What does this code mean and can I do myself?
The Oxygen sensor #1 in Bank2 has been detected as shorted high". (Each side of the engine is considerd a "bank" of cylinders.) There are 2 O2 sensors for each bank of cylinders. The one BEFOERE the catalyst is #1 and the one AFTER the catalyst is #2.
SO...what exactly does this mean? It does NOT necessarrly mean that the O2 sensor is bad. (although it may mean that) It could be a wiring problem (insulation on a wire has worn thru.)
Most mechanics would blindly replace the O2 sensor and charge you for it wether it fixes the problem or not. I will let you chose what to do with this newfound knowledge.
Ahhh, you know how to use a DVM... this is good 8-) I just ready your bio. ... you are experienced in electronic test.
(I am trained in electronics myself) That explains why you were so specicic when you originally described the problem 8-)
I have the BOB (Big Orange Book.... aka factory service manual) for my 2000 Dakota. I have access to all the schematic diagrams. Unfortunately, the schematics do not tell WHERE the components are. Thus I cannot tell you what components behind the heater-controls would "click".
I know there is a component on the FIREWALL under the hood. (just below the drivers-side windsheild wiper) that is EXPECTED to click when it is performing the diagnostics for the EVAP system. I wonder if this is what you are hearing?
It sounds as if you have covered all the bases related to fuses, fusable links and the blower-resistor.
If it were me, I would next look to the relays. The schematics show several relays that are used to "power up" parts of the electrical system. Many of the relays are "swappable" which should aid in troubleshooting. Also, check if there is power available at the ciggerete lighter and other "power outlets"
Keep us informaed about what you find.
Also, I have read thru your posts and see that you have the blinkers working now. Please describe the current problems you are now seeing.
I really hear clicking behind or near the left hand side of the ash tray like a relay......... i cant figure it out...as i had said..pulled every fuse and seen ok..unless something underneath/behind that area.... got the days off tomorrow,, and will be pulling that apart to see.. ..again.appreciate any and all suggestions.... i really dont think my fan motor is blown.. but i can force some voltage on that in the next phase of diagnosis..! thx.,,,,ger
Your Dak is old enough to have developed an electrical wiring problem as well. Check the connector and the wiring harness. In this case "shorted high" I think means the PCM is not detecting a O2 state change from cold. (Do you agree, Bpeebles?) The O2 coil could be open and you should be able to measure that with a DVOM.
Good luck & Merry Christmas.
Dusty
Sometimes my 1998 Dakota has tantrums. Sometimes I start it when leaving work and it stalls outright. When it does this if I re-start, and immediately go for the gas peddle it will stay running. I then have to power brake it (one foot on the gas one on the brake) to keep it running so I can go home. About 10 minutes into the drive I no longer have to power brake it at stops. However when I get home (it's a 15 minute drive to get home)I noticed that the sound of the fuel pump was uneven. This does not happen all the time. Remarkably every morning I start it in the garage it has never done this. Only when it's at work. I used to think it was distributor cap related..moisture...because of heavy rains etc. However it's just been very cold and sometimes snowing in the past 3 weeks and it's doing it again. Reason for thinking distributor cap related because it never did this before the tune up I gave it....any thoughts? Did I find the bullseye or should I keep looking?
Does it seem the starter isn't turning the engine over very fast...does the starter just click and not turn the engine at all for a few tries...Does everything seem to work well and the engine just doesn't crank??
Bookitty (Norm)
What has happened is the pressure valve in the steering gear rack has stuck in the full open position. The only solution is to replace the rack-and-pinion steering gear assembly.
Dusty
I've taken dashes apart before, anyone know if it's difficult to replace a heater core?
From the diagrams I've seen it's not difficult to swap it out, just to get to it.
