Evap outlet hose
EZGNEZGN Member Posts: 2
edited January 2021 in Lincoln
I have been trying to source EVAP canister outlet tube and EVAP return tube. Any help sourcing these parts would sure help. 2000 Lincoln LS V-8
Answers
  • thecardoc3thecardoc3 Member Posts: 5,863
    Some of the lines can be made with parts available in the nylon fuel line kits. When necessary, some pieces can be gotten used, especially the connectors for the lines and then the line kits can be used to make the required pieces. A common trick for some of the larger plastic fittings is to use a spark plug coil boot.
  • EZGNEZGN Member Posts: 2
    Thanks for the info. I checked out the nylon fuel line kits. Great idea, this will be the solution to my question. Thank you so much!!
