Auto Transmission flushing
My daughter-in-law took her Ford van in to a quick
lube place for an oil change. They also suggested
having the transmission (160k miles) back flushed
without changing the filter. She did. After driving
approximately 50 miles and overnight the van
wouldn't operate correctly the next day. She called
a transmission shop and they told her not to drive
it, tow it in!
I have never heard of back-flushing a transmission
and not replacing the filter? Any comments on
this?
it, tow it in!
this?
Let us know what happens, and if the lube shop took responsibility.
guitarzan
Community Leader/Vans Conference
1. Do I have the fluid and filter changed or should I leave it? It seems that changing it could cause problems. I had a small leak in the tranny cooler line and I replaced the fluid with ATF+3 (1 litre).
2. Is synthetic fluid better than the AFT+3 or 7176 type?
I don't know if you have seen this site. Check it out:
http://www.allpar.com/fix/trans.html
or:
If you tranny has over 100,000 miles and the fluid is still clean, I don't know if I would change it. Do you know for sure if the fluid has ever been changed? I guess if you have owned it since new, you'd know. I have heard people say if you haven't changed ATF at or before 60,000 miles, don't bother changing it at all, but I have no idea how valid this advice is.
Dave
http://www.thegrid.net/thedrivetrainpage/whtobuy.htm
The filter is necessary to remove the hardpart and failed clutch material from the fluid caused by overheating.
Asked a local DC dealer about this-he showed me their ATF. They get it in big jugs and decant it to quart jugs. Their new ATF is reportedly backward compatible with all previous DC auto trannies.
I am also very suspicious of those people offering tranny flushes-no way in hell are they going to have the specific fluid for your vehicle unless they are a new car dealer.
These new trannies demand a specific ATF-if you want to be a pioneer-go right ahead and put in somebody's Snake Oil ATF-In about 5K miles be prepared to replace your tranny. Also changing tranny oil is easier on most vehicles than changing motor oil. Just drive it long enough to get the ATF hot and watch out for the hot oil-it is over 300 degrees F-will burn hell out of you.
I don't know too much about the back flush process, but it sounds way to complex for the quick change oil guys to handle. I wouldn't trust them to install a pcv valve correctly.
New transmissions, according to a tranny tech I met, are not as sturdy as the old TH350's and C5's of yesteryear. What was steel is aluminum; aluminum is now brass, brass is now plastic and plastic is now pressed fiber. It is best to follow the manuf's recommendations for frequency and procedure and have a qualified tech. (tranny shop, good mechanic, or dealer) that you trust perform the work.
P.S. See my posts in Transmission Traumas to read more on my escapades. I didn't service mine when the book said to and I'm paying for it now.
10 years,I change it at 3 yr. intervals.this oil
does not varnish or break down like conventional
trans fluids.The "manufactuers" said the same
things about mobil 1 and other syn eng oils when
they first came out.Look how many GM cars are
shipped with syn oil now ! The bottom line is
that syn oils extend the life of the transmission.
Let's face it,the car makers do not want these
vehicles to last forever.
I am getting to be an expert on DC transmissions whether I like it or not.
I have a 1996 and a 2000 GC with 3.3L.
The powerflush is not really a backflush. They just connect the transmission to a reservior of virgin fluid and let the internal transmission pump draw it in, run it through and then into a waste tank. It is the only way to get near total fluid replacement.
Just replacing the 5 quarts or so that goes with a traditional drop-the-pan filter service is like taking a shower and putting your dirty clothes back on.
I have spectrographic oil analysis to show the difference. See topic #970 for the skinny.
best of luck
THERES NO DIP STICK ON THIS ENGINE,SO HOW DO i CHANGE IT
They cost $7.50 plus tax per test (includes test bottle, business reply mail bottle).
If you are comparable (could not find pricing information at your website) I would like to send samples to both you and Schaeffer for compare and contrast.
I am doing battle with silicon contamination in my Dodge Grand Caravan engines and transmissions.
I have a 1996 and a 2000. I have high silicon in both the engine and transmission of the 2000 and in the transmission of the 1996. Using Texaco Havoline 10W-30 in the engine and ATF+3 (Type 7176) in the tranny - Chrysler house brand in the 2000 and Quaker State in the 1996.
Wear metals have dropped to normal after multiple engine oil changes and transmission powerflushes, but silicon continues to persist.
Have also tested transmission samples from co-worker's 2000 GC and neighbor's 1998 GC - both of those also have high silicon.
All have 3.3L engine.
Any insight you might have on this problem would be appreciated.
You can contact me directly at hooferpm@cs.com
best of luck
So the one micron is a stretch of the truth,the element may indeed (not likely) filter to 1 micron,but I can assure you that more than 1 micron is making it to the engine. I don't see how they can make that claim when an expensive high filtration,high pressure hydraulic filter only filters to 5 microns. I'm not saying it is a bad thing, I'm just saying that the numbers they throw around are misleading.
filter is so here goes.
It is a seperate filter system designed to be
used in conjunction with your spin-on filter.
It consists of a filter mounting bracket,a spin
on filter(made by amsoil,3 sizes from about 1 to
3 qts.and filters to the one micron size)and hoses
to mount.you tap in to a oil pressure source
usually a tee at the oil sending unit,this goes
into the filter housing,another hose goes to a
non-pressure point to return the oil,usually the
oil pan or valve cover.I have used these and seen
them on many dif. cars with no problems.
best of luck
My Buick dealership did my '91 LeSabre using the backflush method ($79.00) at ~110K, the second time the oil had been changed. If a dealership is recommending this method, it should be OK. They'd have to take the responsibility of damage if something went afoul.
Jim M.
Town Hall is fortunate to have an experienced Honda tech hanging out in that topic who has been very helpful to our community members with Honda maintenance and repair questions.
Pat
