Can someone identify this car
LostInMaineLostInMaine Member Posts: 1
edited March 2021 in Ford
Recently purchased land and this car was found on the property. I know it is a FORD. but any thoughts as to the model year or value?
  • stickguystickguy Member Posts: 54,754
    scrap value most likely, if it is even cost effective to haul it out of where it is.
  • fintailfintail Member Posts: 59,090
    Looks like a 65 Ford Custom 500 with a custom paint job. Unless it has a 427 under the hood, or was a 427 car, not insanely valuable, and restoration would be a money pit.
  • au1994au1994 Member Posts: 3,854
    Looks like a mid 60’s Fairlane coupe. As @stickguy said not likely much value there unless its really easy to haul out. Looks like its sunk in the ground so major rust is an issue. If you’re industrious and there is any easy to get to trim type parts you might pull those off and try to sell as people are always looking for those when doing a restoration.
    No idea what engine (if any) is there but that might be worth a few bucks to the right person if its one of the V-8’s Ford offered.
