currently im working on a 2006 toyota avalon with a push butten.
smartmind2020
Member Posts: 2
when i put the battery head, the ignition light and all other lights comes on without me turning on the ignition. all fuses & relays are good. what is wrong i need help right now.
Answers
What happens when you attempt to lock/unlock the doors with the remote?
What happens when you push the power button one time WITHOUT stepping on the brake pedal?
What happens when you push the power button two times WITHOUT stepping on the brake pedal?
In these cases do accessories like power windows and radio operate?
What happens if you push the button pone time while stepping on the brake pedal?
What happens if you take the key FOB and hold it right against the power button when you press the power button?
Has anyone connected a scan tool and attempted communication with the onboard modules?
If communication is established what codes were found in which modules? Was there any modules missing from the list?
