Don't wanna blow coolant system! 23 psi for Pressure Leak Test?
I don't want to blow the coolant system! Is much higher 23 psi rating true? [1998 Nissan Quest or Mercury Villager]
Please help! My pressure leak testing is delayed only because I found differing PSI numbers for the radiator SYSTEM. I will be using the Powerbuilt tester loaned from Autozone. I found the following numbers from various sources below:
...Leakage Test Pressure 157 kPa (23 psi), Cap Relief Pressure 81-109 kPa (11.8-15.8 psi) from sources:
+Villager [Chilton online via public library]
+Quest: [Chilton online via public library: can't seem to find spec]
+Quest: [FSM [factory service manual]
...16 psi???
+Haynes book for Quest/Villager, which didn't see mention of 23 psi:
page/section 3-1 "radiator pressure CAP rating" = 11.8-15.8 psi
page/section 1-2 "radiator CAP pressure rating" = 16 psi
Printed psi on cap itself:
+current on van: no spec. I don't know if OEM or 3rd party
+Oreilly, Autozone: 13 psi
+dealer: cap no longer available and no spec
...16 psi???
Answers
I would pressure it to 13 PSI- that should be sufficient to find any leak
Most vehicles are in the 13-16 Psi Range
Some leaks can be internal and slow. We sometimes have to leave the tester on over night and then look into the cylinders for coolant in the morning. Remember , as an engine heats up, things expand and leaks can seal up. small leaks can all dry up and evaporate with engine heat and wont be spotted.
Also dont forget to pressure test the cap, Some caps can not hold system pressure and fail a pressure test.
Fyi been at this game since the 60's
