Dodge Dakota - Regular Cab
                    spokespersons...Here's your special area.  Enjoy!
Bonnie Rick
Conferences Manager, Edmunds.com Town Hall
Bonnie Rick
Mailman
Bookitty
I've had my RC for a couple of months now. Just love this truck. I keep making excuses to drive it. Sort of like that new Honda commercial where the wife needs milk, the husband gladly volunteers to go get it, but brings back chocolate milk (on purpose) so then he has to make another trip to the market. That's me!!!
Thanks again...
Tim
Mailman
I was kinda leaning towards a Gibson as that's what I had on my 97 Dakota CC and I liked the sound, not too loud but not stock.
Any ideas any one?
Keith
I guess I'm looking more for the sound and the look of that 3.5" polished stainless tip. Just a little something to say 'I'm not stock'. I took out the entire stock air box assembly and fabricated a K&N Cone style for the intake, and now I need to open up the exhaust.
Well, I have a saws-all and a welder so I think I'm going to get the Club model and make it fit.
Keith
Mailman
Mailman
it will be installed next weekend. Perhaps a little additional weight will help. We'll see. Nevertheless, it won't stop me from enjoying this
truck. It is such a pleasure to drive. It's like taking a little vacation every time I'm behind the wheel. At the end of the work day, I find myself anxious to drive it home because it is so much fun! Do I sound like a kid? Yeah, I guess I do...
"south end" dancing about. Some recommendations were related to air pressure in the tires, as the factory inflates the tires relative to carrying the rated payload. This is certainly the most obvious and easiest fix. If you haven't checked that out and eliminated this source, you may want to try it. If you have, this is of no help and I have exhausted my limited knowledge.
Bookitty
I like to keep my tires inflated 35-38 lbs as it tends to reduce rolling resistance and heat buildup.
Keith
Mailman
they are a bit high - 40lbs. I didn't think to check this since getting the truck from the dealer. I'll run them down around 35lbs.
Read your owners manual about tire pressures. The 10.5 X 31 tires MUST NOT BE RUN AT HIGHWAY SPEEDS unless the tire PSI is high enough. Apparently these tires cannot dissapate the internal heat generated by the additional rubber-flexing caused by the lower PSI. This may lead to the tread coming off of the tire.... Dare I say it... the firestone syndrome!
Remember;
Reducing the tire PSI will have a negitive impact on your MPG.
On the good side... the ride quality will be improved with less PSI.
Also, any comment on the mpg for this set up? I think it has the 3.92 gears.
I appreciate your comments.
I've got the 4.7L engine in mine. 5-speed, 4X4 with the 3.92 gears. It gets a consistent 17MPG. My brother has the 5.2L in his 1/2 ton and he gets 15-16MPG. If you get a chance, test drive the 4.7L Dakota. Great engine...
Brian
Mailman
Yea, I'm still loving my '00 RC as well. I've got it pretty much fitted out the way I want it. The last two items on the wish list would be a larger fuel tank and the anti-sway bars...
I plan on doing some off-roading during the holidays. Although my wife and I inadvertently did some 4-wheeling on our way to dinner last night. We took a back-route to the restaurant and came to a road that was closed because it crossed over a wash that had some standing water and lots of deep, loose sand. I offered to turn around but the wife said let's go for it! I said "OK" and put it in 4-HI and just plowed right through. Yea, I know, not too smart. But what a blast! Keep in touch and happy RC'ing...
Brian
Keith
Bookitty: Maybe you can tell me a way to increase the mileage on my odometer without driving my truck. You better hide your response. I don't want the forum police to bad mouth me for doing something illegal!
Bookitty
Have a good holiday!!!
It does have limited slip differential-is that at all helpful during the winter?
Any comments would be very much appreciated
I have the same problem when driving in snow with my 2wd RC, but I use something a little less permanent to solve my problem. I have a leer cap on the back that adds some weight, then I add 3 or 4 50lb barbells between the wheel wells and anchor them in place with adjustable cargo bars. When the snow goes away I take the barbells out. Works fine out here in Virginia during the few times it snows.
Mailman
differential, good tires all the way around and prudent driving, you should realize very decent tractive effort.
Bookitty
My past pickup experience was with a 83 ford ranger, 2wd, no limited slip axle. Basically a one wheel drive.
YUP, I use to get stuck alot.
I made a roughly built framework out of 2x4 lumber so weight could be placed directly over the rear axle.
Weight over the rear wheels helps ALOT.
Good meaty snow tires are also highly desired.
With the ranger ,it got to the point, that if I saw a single snow flake falling, I would take the day off if I had any sick or vacation days left.
My new Quad Cab has 4x4 and limited slip rear.
I have not had a limited slip axle before so this winter will be my first experience.
We had a dusting of snow the other day but not enough to engage the 4x4. Can't wait to try it in the snow.
my 98. I was checking everything. It turns
out all that it was was a bad battery. The
dealer replaced it for free, it's been fine
ever since.
Xena1a: Haven't heard from you in a while. How is the truck doing?
Mailman
Brian
Anyways since im here I might as well ask: what is it exactly that persuaded all you to go with RC rather than CC or QC? My heart is set on a certain CC Sport 4x4.
Mailman: Had the EXACT experience- saw the save-a-load in the back of Truck Trend. good to hear from someone who owns one. Now I definitely have to get one to hold my skis down! Thanks!
The Mailman Delivers
