Isuzu Rodeo high idle problems
Hello everyone I have a 1991 Rodeo 3.1 with an
idle issue. it is at 185,000 miles and has
slowley developed an idle issue.
@ 115,000 miles it recieved a jasper engine.
@ 135 the idle problem started.
it likes 2500 rpm and two things will change its
mind (for a minute anyways untill the light
changes) 1: flashing the ignition switch works
half the time and 2: coasting in gear untill the
point where speed matches gear and the tranny is
neither pushing or pulling and then the engine
will chug and i can press the clutch in and idle
is fine....
i have replaced a slew of parts
including plugs cap and wires, many vaccume
hoses, MAP sensor, IAC (idle air), TPS, and
carburator gasket (its really a TBI unit)...its
time for either an EGR ($65) or fuel injectors
($105 each) does anyone have any ideas? How can
i test the injectors? Test EGR? I would really
appreciate some help this is killing gas mileage
and clutch!
is fine....
and clutch!
I have a 91 Isuzu Trooper, 2.8 TBI.
Two problems:
It takes about 10 tries to get the truck to start. I have to keep my foot to the floor or it won't start. It runs real rich until I get the revs up to 3-4K rpm. Then it clears up.
It does this every time I try to start it, warm or cold.
Once it starts, then it idles at around 2K rpm.
If I block the air feed to the IAS, I can get the idle down to around 850 rpm. I replaced the IAS, but there was no change. TPS is correctly set also.
The high idle sounds like a vacuum leak, but I have yet to find it. Don't know if the hard starting is related, but I assume it is.
Help!!!.
My Rodeo would rev to 2500 rpm when the clutch was pressed, sounded like John Force staging at the Gator nationals !
The only slight difference is that when I tried to start it without the ECM fuse in place, it wouldn't. So, I just cranked it a few seconds and stopped. Then put the fuse back in place and followed the rest of the directions. Bingo! Test drive proved no more problem.
Thanks, Thanks.
:shades:
Cheers Kev - ozziwi
Brisbane Australia
Got mine used about 2 months ago with 222,000 miles from a car auction but it was very well maintain for what I can see, but after a week start idling to around 1500 to 2000 rpm. Went to Auto Zone and got a product called " Sea Foam " and added to my full tank of gas and after a week is idling at 750 rpm that should be normal idling speed . And by the way there is no idling adjustments on the ones w/throttle body. Good Luck. Hope this help in some way.
or maybe its not the lack of air it may be Too much air i dont know.
After disconnecting battery or removing intake parts (Throttle Body or replacing IAC for example) you may run into symptoms that when starting the car the engine run on high 2500 RPM or very low RPM or rattling. In these cases you may need to run idle learning procedure. This process is learning the EMC to properly read and control the IAC (Idle Air Control valve).
• Pull the ECM (Engine Control Module) fuse.
• Started the engine few seconds (5 sec) and stop (the engine will not start because the ECM is not active).
• Turn the ignition Key to OFF position
• Put the ECM fuse back
• Turn the ignition Key to ON position, then push slowly the accelerator pedal until the end and release all the way back slowly. Push and release 5 or more times
• Start engine, run for 3 seconds (engine might still run high RPM)
• Shut off for ten seconds, then restart
Enjoy, I hope it helps
If you suspect an idle problem, does NOT MATTER the vehicle, test is the same. What you first want.to look for is a vacuum leak.
Its easy to find, go to [non-permissible content removed], get a smoker for about $30 is what I paid. hook it up to any vacuum line, make sure to plug the.port you pulled off the line from. Do NOT START.THE VEHICLE, turn the smoker on amd LEAVE IT ALONE, once it gets going, trace down smoke, let it keep going just.mark the leak amd keep going. Once.i.had a vehicle was on it for 2 hours. Finally.all of a sudden the rear.bumber started.smoking like I blew the head gasket. It was so bad I had.to raise the garage door. The smoke is harmless, but I had a loose clamp.on the evap system located at the gas tank.
Once you.let it work maybe 2-3 hours amd replace any.vauum limes smoking. leave it smoking, start the engine and turn everything off. And let it work, if the engine impact a.leak, fix it. Sometimes you find a gasket leak (oil pan, valve.cover, etc.). Once you plugged the holes, you are probably best if you just get a roll of vacuum line from parts store.
Hook a ting light on it. Most timing belts are a maintenance item. it is supposed to be changed 60k-80k check your book for right miles. Hope this helps!!
