Rear clunking
GMC7_417575GMC7_417575 Member Posts: 2
edited March 2021 in GMC
There is a clunking in the rear of my Yukon Denali and I'm about to sell it. So far, I've replaced - Shocks, Compressor, Sway Bar bushings and links, Spring insulators, pan hard bar, checked brakes, rear window and latch, both rear seats, checked lug nuts, hitch and cover. I've crawled under and lubed every moving point. I've zip tied the 3 aluminum lines that run underneath from front to back. It is driving me absolutely bonkers. PLEASE HELP!
  • GMC7_417575GMC7_417575 Member Posts: 2
    I forgot to mention, I've replaced the rear tire carrier and the spare is tight. I've also taken out the jack and all hardware of the rear storage area.
  • rickdonrickdon Member Posts: 123
    Could be a dry slip yoke. Try to check it.
