Subaru Crew - Future Models II
1324325327329330446
    My apologies, Im not sure I follow. Is there a press release? And why do you think the OB XT and VDC are going to be in the 34-35K range now as opposed to where they are?
    -Joe
  • sweet_subiesweet_subie Member Posts: 1,394
    extra 2k for nav. currently the msrp is 32-33, with nav it will go for 34-35k. it puts OB in tribeca category
    Might get realigned.
    Notice how the H6s often sell for less than similarly equipped turbos. Plus they're adding an H6 cloth model and deleting the cloth turbos.
    So there will be a shift where the H6 will be the more affordable model and the turbos will cost more.
    I suspect the VDC will drop in price, because right now it costs $1150 more than a similar Tribeca. Or they might toss in NAV and keep the price where it is.
    -juice
  • kenskens Member Posts: 5,869
    I would guess Subaru would keep the price point but increase content. Typically, that results in more profit for a company.
    I wonder about HID lights for MY06. The B9 didn't get them so I wonder why the Leg/OB would.
    Ken
    That would be news to me. To be honest I kinda doubt it, unless we see a Spec B or some other special edition later in the model year.
    -juice
    this means 2005 OB buyers are losers ?
  • mayberryguymayberryguy Member Posts: 145
    I was surprised by the HID move too since I have seen no mention of it here. I saw it on one of the option spec sheets from the plant. This was a production spec sheet so I would be surprised if they dropped it now. I guess we'll have to wait and see. The HID option only showed available on GT LTD, OBK XT, LL Bean & VDC models.
    Yes the 2.5i SE (Value Package) is a base model that adds the 8way pwr driver seat and moonroof. It will be available in both color cloth interiors.
  • bigelmbigelm Member Posts: 995
    You know.. Subaru sometimes confuses the mind to understand any logic to their strategy. Apart from the horrendous, idiodicy (is that a word?) and stupid moves they've made in the past, you figure they'd learn their lesson by now.
    Anyone care to explain to me why the B9 being their flagship vehicle, doesn't even have the HID as an option and why WAIT TILL NEXT MODEL YEAR (if even that)???
    I'd love to explain it, if I could...
    The only thing I can come up with is that Subaru likes to add something new each model year, so that they have something to talk about, as it helps keep Subaru "perpetually" in the news.
    The only other answer I can come up with is costs. Rather than a big jump in price for this all-new model, thay can offer it the first year at a fairly reasonable pricepoint, and then raise it each succeeding year by offering more content.
    I was also surprised that Subaru did not offer auto/down power windows on this model, as that is now almost a given in this price range.
    Bob
    No, because there are incentives right now that "correct" the street price anyway.
    I suspect we will see lower MSRPs with smaller incentives as well.
    2.5i SE sounds good, cloth with a moonroof. If the seats are heated, it's perfect. :)
    bigelm: easy answer - they had HIDs for the Legacy on the parts shelf from models in other markets. For the Tribeca they need to design new ones.
    -juice
    I hope I can get it for the B9 when it comes available, otherwise so be it if aftermarket.
    I may be in the minority here, but with good projector beams, are these really necessary? I'd rather replace a $10 halogen bulb every 7 years.
    If you require them, then ask yourself, should you even be driving at night?
    -juice
    I think it's personal opinion and choice. HID's help and illuminate the road much better than your conventional bulbs or projector beams (though it is a step above bulbs). When driving in areas that have limited light on the roads, these HID's come in handy.
    It depends upon the application.
    For instance, my '98 Forester has very good lighting, even stock.
    My '93 Miata's lights were just awful. It used sealed beams. I bought E-codes, enclosures that basically take an H4 bulb insert. They are 4 times better. Not HID level, mind you, but they offer good visibility for the speeds we see on US roads and highways (usually below 80).
    I guess if you do a lot of high speed driving in Montana you might "out drive" your regular halogen lights. So maybe it depends on the type of driving you do. Or like you said, dark country roads.
    Bob complains that his '01 Forester's lights are not as good as my '98, so it might even be correctable by the design of the reflector.
    I just think HIDs are a bit overkill for my needs.
    -juice
    is projector beam the bulb itself or the assembly ?
    if the latter, HID would be better. also, i would think subaru-made HID should be better than the current ones
    But I do a lot of back road late at night driving. Also i use Hella Micro DE HID driving lights to supplement the headlights on my older subies cause the fluted glass is horrid. On the Armada the headlights stock are pretty good so I may not bother with aftermarket lights on it.
    I do like the auto-up/down front windows on it, they even roll down if you hold the keyFOB unlock button after unlocking the car. Lots of classy things on the Armada considering it's just a nissan.
    -mike
  • locke2clocke2c Member Posts: 5,038
    necessary? need?
    absolutely not. my uncorrected eyesight is quite poor, but with contacts it is fine at night. (some people are worse at night, it's not that uncommon, but I don't have this problem.)
    but need aside do I like HIDs now that I own a car with some? oh, yes. absolutely yes. they are very nice and I'd try to have them on any other new car I get. I might buy a car without them, but I'd prefer that it had HIDs.
    let me ask you, Juice... have you spent significant time (say 8 hours or more in the seat) in a vehicle with HIDs?
    ~Colin
  • saedavesaedave Member Posts: 694
    I am not sure the maintenance and insurance expense for HIDs are worth the gain in lighting distance. I had both high and low beam HIDs on my VW W8 Passat wagon that I traded on my VDC. The lighting improvement was only useful at 2AM on empty North Dakota roads at over 100 mph. Even on very widely divided interstates I got flashed to dim from the opposite direction and annoyed cars far in front of me. I find it hard to overdrive my VDC's lights up to 80 mph, but maybe old age is reducing my interest in "gee whiz" gadgetry. :)
    HIDs are being stolen from various Nissan models: Look for that to happen with Subies too.
  • njswamplandsnjswamplands Member Posts: 1,760
    eyes grrr , i wanna nuke every one of them. great for the driver, horrible for the other driver, downrite dangerous.
    You gotta get LASIK Colin, I used to be blind as a bat and now I see better than I did with contacts or even glasses.
    Not any significant time, no, Colin.
    I have experienced plenty of glare staring directly into SUVs that have them in the Miata, though. Even when they pull up behind me and the top is down at night. My entire cabin lights up. ;)
    I'm just putting the brakes on the "arms race". When we see HIDs, people will want double HIDs, for the high beams. Wonder what a fender bender will cost to fix, also. A stock halogen lamp is just $125 or so. Plus $10 for the bulb.
    -juice
    those HID's that blind oncoming traffic or those driving behind you haven't balanced their headlamps or are just jerks!!!
    juice,
    Note my comments on double HIDs above. The fender bender could cost more than $1,000 if I recall correctly.
    Dave
    On my Passat W8 the double HIDs had automatic leveling, but even on low beam many were annoyed. Of course there are those who flash anyone with blue beams.
    Not really, bigelm, when they drive over the crest of the road it happens, or when you're just lower than them. Roads aren't level.
    -juice
    That I'm aware of, as it's happened to me. But that's just about with any headlamp that has good beam output.
    For instance, a person driving an Explorer with aftermarket HID's, and they're usually like 8000k (unnecessary if you ask me), use them without leveling the beam (and if you can't then don't use them or change the housing) and since the headlamp reflector was not designed for the HID's, the beam is all over the place.
  • francophilefrancophile Member Posts: 667
    The STi HID's are very good lights but are low beam only. (The projector high beams are wonderful also, so the total lighting package is outstanding in my experience.) No automatic leveling, there is a manual control instead. Very nice, to my admittedly "let ME do it!" mindset. When I'm in any amount of traffic at all I run them down manually, so as not to bother other drivers. I haven't been flashed yet but I've only owned it a bit over a month.
    Cheers,
    -wdb
    my Evo has exactly the same, manual leveling. also, the stock beam pattern hit ground about 25-30 feet in front of the car, which was weird because it was intensely bright but had less range and useability than the halogen projectors in my previous car ('95 M3).
    so of course, I went to an Evo enthusiast site and found how to adjust them. I leveled them 2 notches down, then brought the beams up to where they originally shone on my garage door. I drive around with them leveled 1 down, so in effect I'm 1 notch "higher" than stock if that makes sense. it improved the usability a TON but I do get flashed about once a month. usually I don't react. if they're a long ways off and don't flash but instead leave their high beams on, I kick mine on and burn them off the road. LOL
    I can go 2 more notches down, or 1 notch up if I'm on backroads with absolutely no one else around. 1 notch up + high beams = who needs driving lights
    ~Colin
    from your blinding glare. do u really need to see every cockroach on the road?
  • rob_mrob_m Member Posts: 820
    Any new colors for the 06 Legacy? Rob M.
    The STi low beams seem to be well aimed height-wise, at least on my car. Also the lighting is very evenly dispersed; no hot spots or blind spots, just a nice, even spread of light. I'm by no means an expert on these things but I am very finicky about lighting, to the point of having upgraded the lights in one way or another in almost every car I have ever owned. In the case of the STi I don't think I'll have to do any mods in order to obtain lighting that is satisfactory for my tastes and needs. This is far and away the best factory-supplied lighting I have ever had on a car.
    As far as being flashed or not, and/or *my* HID's posing a hazard to oncoming drivers: there are a whole lot of wannabe HID's out there, aftermarket blue-tinted bulbs with all kind of fancy sounding names. From what I have seen of them they generally have horrific beam patterns and hit oncoming drivers with annoying, dazzling glare. I've been hit with it plenty of times myself! Sadly they give the whole HID lighting market a very bad name.
    In contrast to those, the beam patterns on the STi -- and most other factory supplied HID's I've seen so far -- are very precisely controlled and, while they do (or used to) catch attention because of their obvious color difference, they do no not blind oncoming drivers. I have had many instances of being able to look directly at the headlights of HID equipped cars without suffering from glare. I can't say the same for very many halogen headlights out there! Plus HID's come with either automatic or manual leveling systems to ensure that the beams stay where they belong.
    One place I do have a problem with HID lighting is the same place I have a problem with most any other high output lighting; SUVs and pickup trucks, in particular the 4WD models that seem to be in competition for the "doorhandles the greatest distance from earth" award. Often their lights are so far off the ground that there is simply no way they can be adjusted so as not to blast into the eyes and mirrors of any non-monstrosity they encounter. I'm all for a federal mandate limiting the height of headlights on all vehicles. Let the designers figure out how to make them look good!
    Finally, if I may, I'd like to offer a trick I learned during my days of long-distance bicycling. Often we would ride our bikes at night. The lights on bicycles, while entirely sufficient for speeds up to 20mph or so, are nevertheless *far* less powerful than car headlights. Riding along in the dark your eyes naturally adjust to that amount of light and you can safely ride down the road. But when a car comes along the headlights hit you, your pupils contract in response to the added light, and after the car is past you can't see much of anything for a long moment until your pupils dilate again. Not fun! And of course potentially dangerous.
    What I learned to do was to look up the road *past* those headlights, keeping my focus on my side of the road and the course I was on. Another way of putting it would be to say that I moved my gaze a bit down and to the right. By doing so the impact of those oncoming lights was tremendously reduced and I was able to maintain my night vision. I quickly learned that the same trick can be used when operating an automobile at night; when you see oncoming lights -- especially if they look like they're going to hit you with a big dose of glare -- move your eyes a little bit down and a little bit to the right. Keep your attention on your lane, on where you are going, and look *past* the oncoming vehicle and its annoying lights. Try it, I think you'll like it. I personally find it to be a great blood pressure reducer ;)
    rgds,
    -wdb
  • subearusubearu Member Posts: 3,613
    A friend of mine just got a leftover '04 MX-5 MSP which has projector beams. Very nice sharp cutoff. Amazing how they light the road up. If anything, projector beam headlights should be standard equipment.
    The only HIDs I don't care for are those in the newer Maxima's. For some reason, the driver side beam can glare onto oncoming traffic, evne though I think they're auto leveling. Enough to make you *think* they have brights on. It's the only HID equipped vehicle (even including SUVs) that I've not particularly cared for driving past.
    -Brian
    nothing like an HID cresting a right hander hill and blinding me going into a corner. u r right some HID knockoffs blind a driver no matter the angle but given the hills i live in i have been blinded by many a bmw, mercedes and acura
    Wife's 626 has manual leveling, but we never used it.
    -juice
    http://www.subaru.co.jp/forester/stiversion/
    • 2.5 turbo
    • 6-speed
    • 18" wheels w/RE030 tires
    • Sport suspension
    • Brembo brakes
    • Suretrac
    Bob
    That's it, I'm moving to Japan. ;)
    I'll even take that color. In fact I'll take that exact vehicle from the photo shoot. :)
    -juice
    sure trac ?
    LSD for the front, like the '05 WRX-STi.
    Bob
    While the lighting on my 05 Legacy is by far the best of any vehicle I've owned, I do admit that if it was offered with the option, I would get HIDs. It's obviously not a deal-breaker for me, but I can't but imagine how much better night driving would be if I had more lumens pumping through the already efficient and focused projector beams.
    Ken
    The HID's on the STi aren't projector beams. The high beams are, and they are great, but they're halogen. The low beams are reflectors.
    By the way, HID low beams = no daytime running lights via lower powered low beams as is common on Subies. My STi has no daytime running lights period.
    rgds,
    -wdb
  • volkovvolkov Member Posts: 1,306
    Don't move. We just need to convince someone to embark on a bold new Grey Market business. :blush:
    Why has FHI always been so reticent to export these variants? :confuse: I'm sure a run of F-STi's would sell like hot cakes in NA. Sure the WRX would have sold strongly long before 2002 as well. The tooling is already there with the possible exception of 5 mph bumpers. I can't see it costing anything to take the risk, and it would generate serious hype in the magazines.
    Nicholas
    That's the idea, sell just 2000 of them, seriously. It would create a buzz and a real nice halo for the XT model.
    -juice
    Thanks to Ken, here's a translation of a press release issued by FHI on the JDM Forester Sti!
    Here are what I believe to be key points from the JDM Forester STi press release:
    Subaru Announces the addition of the Forester STi Version
    - Available from May 6th at dealers across from Japan
    - The Forester STi Version was designed as a "Pure Sports SUV" with excellent road manners. Key features include:
    > 2.5L DOHC turbo engine
    > 6 speed manual tranny
    > 18" wheels
    > Brembo brake system
    > Custom front bumper, grille, bucket seats
    > 30mm lower suspension vs. standard Foresters resulting in 170mm ground clearance
    - The Forester STi was designed around the concept of delivering the "Best of Both Worlds" and features both dynamic and clean exerior styling and exception handling.
    - The STi Version has received popularity since it's addition to the Subaru line up in Feb 2004.
    Key Features
    - A 2.5L DOHC turbocharged engine that produces 20-25% more mid-range torque by means of a larger exhaust, turbocharger and intercooler compared to the 2.0L DOHC turbo used in the 2.0XT model.
    - Semiclosed deck, strengthened pistons and control rods to address the maximum torque of 37.8N-m.
    - 6-speed gear ratios selected especially for the STi Version
    - Chassis rigidity increased by strengthening front strut attachment points, front cross member and suspension mounting points
    - Suretrac LSD added to improve cornering performance as well as stability on slippery surfaces
    - Inverted struts (front and back), bigger rear sway bar
    - 15.0:1 steering ratio, power steering tuned especially for the STi version
    - Brembo brake system with strengthened brake booster, low flex brake hoses improve brake response
    - Exterior treatments to allow immediate identification as an STi model: bumper, grille, front and rear STi logos
    - Alcantra and bucket style seats (front only) provide superior support
    - Reclining rear seats, 60/40 split to maintain SUV functionality
    - Featured body colors: Pure White, Obsidian Back Pearl, Crystal Grey Metallic, WR Blue Mica (STi only)
    Specific improvements
    - Improved shift throw feel and action
    - Improved handling feel from strengthened steering rack and gearbox mounting points
    - Reduced steering kickback through damper valves used in steering gearbox
    - 240km/h speedometer (a first for a mass produced Subaru)
    Standard equipment
    - inverted strut suspension (all four corners)
    - 4 pot Brembos (front), 2 pot rear
    - 18x7.5 JJ STi logo wheels
    - 225/45R18 Potenza RE030
    - Front and rear Suretrac LSD
    - Sodium filled valves
    - Strengthened pistons
    - Red painted intake manifold
    - STi logo large intercooler
    - STi muffler
    - Large air intake
    - 6MT
    - Iridium spark plugs
    - Front and rear STi stabilizer bars
    - Leather covered steering wheel, shift knob, handbrake with STi logos and stitching
    - 15:1 steering ratio
    - Aluminum sports pedals
    - STi instrument panels including 240km/h speedo
    - Immobilizer
    - Bucket seats (as detailed before)
    - "Soft feel" center console
    List price JPY 3,118,500 (2,970,000 w/o tax (I think))
    Bob
  • bluesubiebluesubie Member Posts: 3,497
    Yeah, I'll hold my breath for that. :rolleyes:
    I would probably have to trade my FXT for an F-STi. I don't think I have to worry because we can't even get 17's in N. America! I would gladly give up my heated seats for those.
    I said there was no way we would get a 300 hp STi. Prove me wrong again, SoA!
    -Dennis
    I would just have to own one of those. Holy cow, that would be so sweet.
    The only thing I don't like is the optimistic speedo, who will actually go 150mph? You'll only use the first half of that in normal driving.
    But that's like complaining about a small mole on a super model. :D
    -juice
  • once_for_allonce_for_all Member Posts: 1,640
    get the clean-diesel cars going!
    John
  • sdufordsduford Member Posts: 577
    No kidding!
    I was in Italy last week and I rented a Lancia Musa (sort of a small 4 seat wagon) with a diesel engine.
    I did 382 Kms and at least 60% of that was spent in 2nd and 3rd gear through the traffic of Milan and the twisty mountain roads of Lake Como. The gas gauge was still showing above half-full and I had burned only 18 liters. That comes out to about 48 mpg. I'm guessing I could have done 55+ if it had been all highway!
    Sly">
    That's what I want to see. Hybrids are good in city mpg, diesels are good in highway mpg. Combine them and you'd have both.
    -juice
    Maybe the 150 MPH speedo just adds to the allure...........thats what I always thought about Cindy Crawfords tiny mole, though... she seems to have dropped off the face of the earth of late....
    Joe
    I have a 140mph speedo on the Armada and the SVX had a 160mph speedo on it IIRC.
    -mike
