What happens if you accidentally reverse polarity?
My 2007 Hyundai Accent 1.6L 4 door began to turn over more slowly than normal so I suspected a tired battery, however, the 'battery' trouble light had never illuminated while driving. When replacing the battery I managed to reverse the polarity for a brief moment (big spark), however, the car started and the lights worked so I thought there had been no damage. I didn't check the radio or heating fan (blower) at that time.
The starts were normal at first, then gradually got slower and reving the engine did not brighten the headlights so I suspected the alternator and replaced it, whereupon the 'battery' trouble light appeared and stayed on after starting. All the lights still work, however, the radio and blower won't turn on.
The battery fusible links under the hood and the fuses for radio and blower under the dash all have good continuity and the blower relay closes when energized.
Any suggestions for where to look/test next would be appreciated.
Answers
I called the auto vendor and they have agreed to trade me up to a 'better' model.
I can't believe I pulled 125 amps from that reversed battery, so perhaps the old fuse was derated a lot. I made up a 70 amp fuse from 1mm of solid copper until I buy the replacement and bingo, the blower returned and some more searching found the melted audio fuse.
Oh happy days.
