Pt cruiser classic i
VermaakVermaak Member Posts: 2
edited March 2022 in Chrysler
When driving the car sometimes stall what is the reason?
When i start the cruiser to drive i listened to the ideling and sound if it going up and down slightly
Sounds if the idling is to low
Then get the stal problems
I just bought the car second hand
What can be the cause?
Answers
  • oldfarmer50oldfarmer50 Member Posts: 24,820
    Is the check engine light on? If so, get the code. It could be a number of problems but it sounds like either a bad fuel pump or a failing cam positioning sensor.
  • VermaakVermaak Member Posts: 2
    The engine light does not come on..
    Iservice the car minor service but coyld not replace the petrol filter cause its inside the fuel tank
    Not sure how to get it out the fuel tank.
    So u mean the pt also have a sensor for the idling?
    The ref counter does not work and are being replaced (VSS)
    Can that also be the cause for the bad idling?
    edited April 2022
    On most cars changing the fuel filter requires dropping the tank but that would also allow you to check the fuel pump. The camshaft positioning sensor feeds data to the engine computer telling it how much fuel to feed the engine. Usually a bad sensor causes a check engine light.
    It might help if you took it to a mechanic with the appropriate diagnostic tools. Throwing parts at a problem can get expensive quick.
