Bob
Current aftermarket electric brake controls look like they came from Pep Boys; really pretty tacky looking.
Bob
-mike
http://www.motortrend.com/future/2003_2.html
Volvo may tow 3300 pounds, but VW doesn't rate the Passat to tow at all. So it is possible to survive (thrive, even) with little/no towing.
I saw a Ranchero in Orlando at that cruise in. Pretty wild, but ultimately 2 seats limit the market too much. The ST-X has true potential.
Bob: I doubt the Camry would get the V6 from the 4Runner, IIRC that is a truck engine. It could get the more powerful V6 from the Highlander, though.
Also, they can't bore out the H6 - the spacing is already very narrow. Stroke maybe, but even that may require a wider track.
I like small cars, so I like the idea of brilliant engineering as opposed to making a bigger and heavier Legacy. Give us a folding 3rd seat, compact rear suspensions, clever mid-gates on the ST-X, that kind of thing.
GM trannies may be great overall, but dad's Olds Custom Cruiser was awful. When you came to a stop it stayed in 2nd unless you gave it some gas. Then it surged forward. Kind of embarassing on a date (don't ask...).
Yes - I rode the Kraken coaster at Sea World and it was nothing compared to co-piloting for paisan in that gimmick Rally.
I think the trailer sales idea is a bit much for a small franchise like Subaru, but maybe a marketing partnerships would work. They do sell Igloo coolers, Yakima racks, LL Bean gear and Purolator oil filters.
-juice
MT has some of their dates wrong though. They say the ST-X and redesigned Forester will be 2002's. They'll actually be 03 models (unless they're referring to calendar year).
Dennis
The EJ series flat four is used for everything from 1.6 to 2.5 liter.
-Colin
Dennis
Whoops, left a thought off my previous post. My point about the EZ30 was that since they already have a 2.5L four, it would make little sense to consider the six cylinder for smaller displacements.
-Colin
Anybody care to start a pool as to when the next round of Subies arrive? Here's my bet:
MY '02
With the exception of the Outback VDC sedan, I think we've pretty much seen all that' new for '02.
MY '03
Legacy/Outback
Introduced at next Detroit show in January. In showrooms next March. Legacy GT to get DOHC 2.5 w/variable valve-timing, and with a moderate-boost turbo version of that engine too.
Forester
Introduced at next LA or Chicago auto show in January, on sale following September. Based on Impreza, but with 2" increase in wheelbase, and with a low-boost version of the DOHC 2.5. Still built in Japan.
Impreza
On sale in August '02.
BRAT
Introduced at NY auto show in April, on sale in following November. Also with low-boost 2.5 turbo.
MY '04
SVX introduced at NY auto show.
Who's next?
Bob
Though my money's on forced induction.
-juice
-mike
-mike
Bob
Patti
Patti
The H6 could probably be stroked a little, but I doubt we'd see more than 3.2-3.3 liters. IMHO the engine is fine - 212hp is good power.
It's the trans that is the weakest link. Only 4 speeds and geared too tall. Autoweek even mentioned how low the engine revved quite low at high speeds, but it took 8.6s to reach 60mph (though at least they got 21mpg).
Bob: I'm sure you don't expect Subaru to engineer another H6. ;-)
-juice
Bob
But really, 212hp is plenty. Imagine that with a 6 speed on a basic Legacy GT. Or even on a 5 speed automatic Outback.
Sure, a few would ask for more, but it would exceed the needs of 95% of potential buyers.
-juice
PS I hope one thing Subaru does copy from GM is their optional engines sold as stand-alone options. How about $600 for the H6 upgrade?
If I'm not mistaken, the current H-6 is a rather over-square engine. So, they could stroke it quite a bit before it becomes under-square. Even if it were to become under-square, that would not necessarily be a bad thing. It would probably make it a real "torquer."
Bob
-mike
IIRC the GM version will have their 6 and the Subaru version will have the H6. Of course, that's many moons away and things change.
Dennis
-mike
I guess my bigger point is that Subaru should work on the transmission first. Give us 5 speed autos with manual controls, or a 6 speed manual.
-juice
Bob
All boxer engines are massively oversquare. Stroke is severely limited by physical block size, so everyone has long ago realized that they must be oversquare to get reasonable displacement from your packaging size.
-Colin
It's already a tight fit; you have to remove the windshielf fluid reservoir just to change the spark plugs!
-juice
Bob
Vs are angled, so the total width of the engine is not as big as a boxer. Many V6s are only 60 degrees, and VW used a 15 degree design for its VR6, which is much more narrow than an H6 could ever be.
-juice
Bob
Even the score a bit. Japan has been getting all the sweet stuff we've missed out on.
-juice
-mike
-juice
Dennis
Bobby
a turbocharger would be a good way to keep that power.
-Colin
-juice
Could you please explain the logic behind battery disconnection, etc. to "acclimatize" the car. This is for us non-gearheads. What does it do to the car?
Daniel
-juice
Scan down to the bottom of the page on the following (spoz to be) hyperlink. Ah .. make that internet address.
hey it came through ok
- hutch
This isn't at all like Ford reviving the Thunderbird name for a car that looks a bit like an older 'bird. This would be more like reviving the Edsel name. (OK, not that bad but you get my point. The new Explorer probably would be selling much better if it wasn't named Explorer.)
-Colin
The 2 door won't do anything the WRX sedan doesn't do cheaper.
-juice
http://www.subaru.net/prototype/cvt.html
Dennis
-juice
I think Brighton would be a perfect name for a Miata-like Subie.
Bob
Now a REX rag .. that would be hot. I'd have to consider trading in for that one.
- hutch
-mike
