Raw gas coming out of exhaust pipe.
my exhaust on morning smelled of gas so il looked at raw liguid gas running out of exhaust
How is the engine running, is it rough, misfiring? Has the PCM identified a circuit failure, or a misfiring cylinder?
If you are certain that this is fuel and not condensation from exhaust gasses, you really should see a shop. The potential for trouble beyond the injector issue is significant. You could trap fuel on top of a piston and hydro-lock a cylinder. You certainly are diluting the oil which could cause wear inside the engine, and of course there is the risk of managing to ignite the fuel at the exhaust opening.
