charging issues
littleronnielittleronnie Member Posts: 1
edited July 2023 in Dodge
i have a2006 magnum sxt i am stumped!
it will not charge and ive replaced the alternator ,battery and PCM and checked relays and fuses and still nothing
  • thecardoc3thecardoc3 Member Posts: 5,869
    Are there any codes setting in the engine control module?
    Is there power on the red wire at all times?
    The engine control module outputs up to four amps of current on the brown/grey wire and the black with brown should be at a full ground connection. Do you have power to the alternator with the engine running on the brown/grey wire?
