PICTURES Included: Mass Play in Steering wheel
*Please review the photos provided before reading..
Looks as of those two yellow rivets aren't holding the wheel anymore?
The vehicle is a 2010 Escape XLT flex fuel V6 3.0 100k miles. I Thank all of y'all in advance for any advice or replies.
Also which spark plugs are recommended ? double platinum is the recommended metal? I know motorcraft is what Ford uses. .045-.048 gap is what manual says.
Thank you! How do I get to this bolt and are those connectors shown for air bag? Can they be disconnected.. see where I'm going with this
Have you personally done this? Taking the air bag completely out
There's an air bag light on dash been there ever since this started occuring any correlation between the two?
The first one is the bottom of the steering wheel removed and the top of the column where the clock spring is.
The second one is just the clock spring
The third one is the retaining bolt that secures the wheel to the steering shaft.
