04 3.4 RDV AWD
                    OK READY TO BE STUMPED? I have replaced the following and still have rough idle and hard to start when warm.egr valve,iac valve,throttle position sensor,02 sensors,fuel pump,fuel filter,plugs,wires,all 3 coils, had ignition module checked,maf sensor, fuel pressure regulator, pcv valve,checked to see if my model as accelorator sensor, speed sensor,cat converter,exhaust,starter,battery,battery terminals, checked relays,did smoke test for vac. leaks, compression tests, had body module checked, front wire harness to wheel sensors replaced, new radiator,had pcm checked,throttle body cleaned,abs module replaced,surpintine belt replaced,power steering pump replaced,harmonic bal. pulley replaced, all 4 wheel hubs replaced, power steering lines replaced, there is more but i have to go into my file to see. i have a computer file on this car now to keep track of the parts that have been put on it. i have had it to 13 differnt mechanics no one can figure out what is wrong with it. when i drive it it drives great. but it has symptoms of bad accelorator sensor but my car doesn't have one according to my mechanic. my car was built nov. of 03 but is titled 2004. i am at my wits end with this. had it 3 years and mechanics have had it more then i have. i told him we gonna have to do shared custody. i do not like these cars with all this electronic crap on them. pain in my you know what! not worth it at all! HELP! CAN'T STAND THIS ANYMORE! My car would make a preacher cuss!
I could go all through your list but that would only add to the noise. To diagnose your car, the first thing that I would do is forget everything you have already said about what has been done before. I would have to test as if this as if it has never been touched.
So, if I started to look at this for a rough idle, I would want to know are misfires being counted on any cylinders in the scan data? If so which ones. Being a GM has the crankshaft position sensor relearn been performed? What are the fuel trims doing, are they adding fuel? Taking fuel away? Making differing corrections bank to bank? Are the corrections (if being made) consistent through differing engine speeds and loads or does changing the engine speed and load result in different fuel trim corrections?
Has a running compression test been done? Better yet has it been done with pressure transducers and a digital oscilloscope? If so can you share the waveform files? This might all sound like science fiction, but this is exactly how top technicians test today. Find a technician with these tools and skills and he/she will make ordinary work of your rough idle symptom. BTW There is no such thing as an "acceleration sensor". The computer software looks at engine speed and the Mass Air Flow measurement, and then modifies that with intake air temperature, engine coolant temperature, and some of the throttle plate position information in order to calculate the required fuel delivery and then only looks at the O2 sensors to see what happened after the fact. Studying the fuel trim response from the O2 sensors gives the technician proof as to whether the fuel system is working correctly of if the problem might in fact reside there.
If you can get data and share it we can help.
How rough is it? Of course it is smoother with a higher rpm, there is more inertia in the crankshaft so small variations in crankshaft speed are masked. Seriously at this point you haven't given me any information to rule out something as simple as this is a normal vibration from the engine and there just happens to be a bad engine mount not isolating that from the body.
There is a TPS (throttle position sensor), there is no "acceleration sensor". You have to study what exactly the computer software does with the various inputs. Being that this is a MAF sensor system the engine controller pays attention to closed throttle, wide open throttle, and movement of the throttle. Otherwise as far as engine control is concerned the actual TPS information is meaningless except for transmission control. Attached is a portion of the engine schematic. The TPS is on the top right.
This is a twenty-year-old vehicle and quite primitive compared to what techs work with today. Your leg work to this point is showing you a little more what proper testing looks like. That as far as I can tell hasn't been performed. Swapping computers isn't testing and usually doesn't prove/disprove anything unless the result ends up being a lucky guess. Measuring ignition secondary voltage could show variations in the firing voltage and spark burn time which could then be investigated for the cause. Injector balance tests can be performed to make sure that each cylinder is getting the same amount of fuel. Pressure transducers can be used to see if each cylinder is getting the same amount of air. Vibration sensors can be used to confirm if engine vibrations are being directly transmitted to the body. These are just a few of the tests that can be performed to get a direction, there are more depending on what is observed and/or measured.
