1997 Dodge Neon Head Gasket
We have a 1997 with 46k miles, out of warranty,
with a leaking head gasket. Anyone else have this
trouble?
trouble?
I guess you are a newcomer to Edmunds. If you had been reading the various posts about Chryco in general the headgasket failure rate on the early Dodge/Plymouth Neons reached "epidemic" levels. It seemed that many, many owners have had multiple gasket failures, in and out, of warranty. It may be to your advantage to really put pressure on the dealer to at least pay a percentage of the repair (not cheap by the way). Chryco is fully aware of this high failure rate and may indeed help you out (don't count on it tho)if you gripe loudly enough. A headgasket should never "blow" in normal use @ 47,000 miles. They know they have had a problem but hope that if they "stonewall" you, you will just roll over and pay the full shot to get it fixed. If not, I bet your next car will NOT be a D/C product.
Good luck !
Floridian
Jeff
Now I have oil leak problem and service person asked me for $700 to fix it. I have already paid $300 to replace the rotors 2 years before. I will talk to chrysler customer care and keep you updated.
Honestly, I am very upset at this and I am 100% sure it can affect Chrysler sales definitely.
I am looking to buy a used car from a private owner and found a 97 and a 96 neon within my budget. However now looking at all these postings for head gaskets I am getting very wary. Is this something I can look for before I buy the car and how? Are the majority of neon cars coming out with this problems? I will not have a manufacturer's warranty since I am buying a used car.
ksg1
\From: Greg at Chrysler
Greg, something stinks here-- why would Chrysler stand behind so much other work with 12/12, and completely blow off any warranty pertaining to head gaskets?
It is not a new policy. To my knowledge, Mopar h
as *never* offered coverage on seals and gaskets, unless that seal or gasket came as part of an assembly. For example, if you had a complete Mopar remanufactured engine or transmission installed, then the seals and gaskets in that assembly are covered as part of the assembly.
Whether it's a valve cover gasket, a head gasket, a differential cover gasket or a rear main crank seal, there is no 12/12 Mopar warranty on seals and gaskets.
Here's my *personal opinion* on the subject: If a recently replaced seal or gasket is leaking, the failure is most likely due to either
improper installation
a flaw in the surface that the seal or gasket seats against.
For example, the head gasket could repeatedly leak due to something wrong with the cylinder head or engine block. In that scenario, an otherwise good gasket would not seal...
Greg Smith
5.2 Troubleshooting and Maintenance
This section contains problems and questions common to the Neon; it is intended to stay fairly Neon-specific in content. Emphasis is placed on mechanical issues rather than appearance care; however, some aesthetic questions are included. Also, this section is not a How-To list, which appears elsewhere on this site. It is meant as a quick guide to some of the common symptoms and their causes. Another good source of information is the Neon TSB list; some common TSB numbers are included here as well.
5.2.1 Q: Are headgaskets really a problem?
A: The Neon has a reputation for headgasket failure, and it has affected many Neon owners. Since the blocks are identical, both the SOHC and the DOHC are susceptible. Chrysler revised the original gasket twice to address this issue, and finally released an all-new part. The new MLS (multi-layered steel) gasket supersedes the old part under the same p/n. The new gasket went into production SOHCs in September of 1998 (part of the '99 m/y), with the DOHC following shortly after that, probably before November of '98. TSB 09-05-98, which describes the revised part, was issued on November 06, 1998. This means that the new piece was available at parts counters around that time. (Thanks to Greg Smith for this additional information.)
Nearly all failures occur in the driver's side rear of the engine block, where an oil passage crosses between head and block within 1/4" of the outside edge. The most common symptom is an oil leak at the block joint in the vicinity of the brake fluid reservoir. Other, less common symptoms of headgasket failure include: water in the oil (indicated by foam on the dipstick or drain pan), oil in the coolant overflow reservoir, and burning of coolant (continual steam or light grey soot in exhaust pipe). However, most Neon headgasket failures do not cause mixing of oil and coolant.
Two items should be kept in mind on this subject. First, with more than a million Neons on the road, even a large number of failures is a small percentage of the unaffected cars. Second, this problem is common among most cars with aluminum heads, not just Neons. This kind of head design saves weight, and is typical on modern cars. However, aluminum heads are sensitive to overheating and may crack or warp, which leads to gasket failure.
Headgasket failure is enough of a problem, however, that Chrysler has made special provisions for headgasket repairs beyond the normal warranty period. While dealers probably won't volunteer to fix a car that has exceeded its warranty, many Neon owners have found that a call to the Customer One phone number may help. Depending on the age of the car, Chrysler may pay a portion of the replacement cost; in many instances, repairs have been made just as if warranty coverage existed. Also, owners who have paid out-of-pocket to have the headgasket replaced may be reimbursed under this extension. In many cases, full coverage of headgasket failure has been extended to five years or 100,000 miles.
5.2.2 Q: My engine's leaking oil, and I'm scared. Help!
A: OK, don't panic yet. Both engines may leak oil at the cam position sensor (CMP), which is located below the intake piping that leads from the airbox to the throttle body. There is an O-ring seal at this sensor which can fail, but is relatively easy to replace. The resulting oil leak can appear to be either the head gasket or the main seal between engine and transmission. Check this spot first before freaking out.
Another common leak is the oil pressure sensor, located on the back of the block under the exhaust manifold. This is also sometimes mistaken for head gasket failure. Remove the sensor unit using a 1-1/16" six-point deep socket, apply teflon pipe tape to the threads, and reinstall
Also I was wondering if anyone has heard if the evaportator cores on the A/C unit go bad. I tried to have the A/C charged this last summer. The mechanic told me that more than likely the core was bad and it would have to be replaced because Chrysler has a problem with them. Something about the change from freon to R24(?) eats the core up and Chrysler hasn't been able to fix it. I didn't think he was screwing with me seeing he said he wouldn't do the repair unless he knew the new core wouldn't rot out. He did say it would run about $1100.00 to due the job. Well other than these 2 problems the car has been good to me so far. Thanks for any answers
96 Neon
1.Blown Head Gasket @25K
2.Blown Head gasket @35k
3.Blown Head gasket @45k
4.Got rid of it and bought a Camry
ABC (anything but chrysler)
Pat
it was otherwise a great car!
#1) What is a head gasket??
#2) Just before my warranty expired I had the dealer check my car due to leaking oil. They said that oil was leaking into my spark plugs. They replaced the plugs, "fixed" the problem, and sent me home. Now, 4000 miled later and off warranty, my car is leaking again. When I last had my oil changed, the mechanic (nondealer) told me I was better off just topping off the oil than fighting to fix a neon's oil leak. Anyone's opinion on all of this? Obviously I'm not well versed in car mechanics.
By the way, my goal in usefulness of this car is at least 2 years and 30000miles. Thanks so much!
Good luck with the Neon.
Your host, Bruce
When I first called the mechanic at the dealership, I reported it as a failed rear main seal, and he said he has replaced approx. 50 head gaskets and not a single rear main seal on this 2.0 liter engine. (This in a town of 30,000!) Problem is also common to this engine installed in Strati/Cirruses. I also heard somewhere that they are on the 5th iteration of this part number. I believe it was the parts guy at the dealership who told me that.
Bad problem, but I was impressed with Chrysler standing behind their product.
Dave
I got a question about Dodge Neon 1998 (or,
maybe, this is common for all Neons with auto
transmission?...).
I am going to buy this car in a few days and
tested it yesterday. Before I was driving only
japanize cars and and driving Neon was my first
experience with small american cars.
Is it common that you feel when you change gears?
From R to D , lets say.. The car jumping up a bit
every time you change from P to R or R to D ?
I don't feel anything when I do that in Civic...
I would appreciate any answer here, or you can
send it to igna@iname.com
Your host, Bruce
I never have had a leak problem.I have used
amsoil 0w30 oil and by-pass filter since 5k.I do
not know if this is the reason but the engine
generates less heat with this oil.the temp sensor
stays a few degrees below half.
I do own 96 Plymouth Neon Sport, which I bought new. I was happy owner for 4 years and a change. 2 months ago I noticed that something is leaking from the engine compartment. Car was 4 years and 3 months old with 51000 miles. Trip to dealer answers the question. It is infamous "head gasket problem".
They fixed it for 651USD and I asked Service Advisor to put in writing that head gasked was broken (he put note on the receipt that gasket corner cracked or something similar). I made beautiful color copies of my receipts and sent them promptly to DCX. One month later I received phone call that DCX stands behind their products and I will receive reimbursement in the mail.
Today I cashed the check for 651USD.
I still like my Neon even though it is quite noisy (not quiet).
Krzys
I had the engine gasket problem on my 1995 Dodge Neon at 69370 miles in November 1999. It cost 650.00 at a dealership and nobody ever told me anything was known about the problem. Today, May 15, 2000 at 77000 miles, I had my car checked at an independent garage and found out the main rear seal is blown, and that it will cost another 400.00 to repair. This is so outrageous I can't believe it. I will be selling my car ASAP and I will be buying a 2000 Honda Civic. I've had several Chrysler products and I will NEVER buy one again and I will do eveything in my power to badmouth the company! What is wrong with the Government? Why can't they force Chrysler to recall these cars? HELP !!!!!!!!!!!!!
The following week, the engine spit out a spark plug and stripped the threads. The dealership said they needed to remove the heads to rethread, hence a new headgasket for another $650. Go figure. A heliocoil did the job quite well for under $20.
I have a 97 Neon with 35,000 miles on it and it has been the the shop for major things! One of them being the head gasket. I also had problems with the transmission, clutch, and fuel pump to name a few. Luckly it is still under warrenty.
I'm looking at getting rid of my Neon as soon as possible before anthing else goes wrong with it.
This original owner purchased a Premium Care Protection package ($100 deductable) that is transferable, and the 100,000 mile / 6 yr. warranty is also going to be transferable to the new owner as well. Would this not cover me just in case I should have some head gasket or oil leak problems?
She's asking just the pay-off balance ($6,500) but I'm concerned about the resale value. The customer has kept the car in immaculate condition and has receipts for everything and did regular maintenance like clockwork as well. I test drove the car at length and didn't notice any louder than normal engine sounds and my only regret is that I wish it had more power going from 0 - 65 but what can one expect from a 3 speed?
I would appreciate ANYONE'S honest input ASAP before I enter into this deal . . . Plus, I'm getting ready to move from Missouri to Boston at the end of this month so I'll be putting the Neon to the long distance trip test soon after purchase. Please advise :-)
Welcome to Town Hall!
Perhaps you have already found all these other resources here, but I just wanted to point them out in case you have not.
The Finance, Warranty and Insurance Conference is a good place to pursue your questions about the Premium Care Protection Package. The Smart Shopper Conference is a good place to check into things like used car pricing and resale value.
From your ID, I assume you are a woman. If so, you might also like to take a look at the Our Turn Conference which is dedicated to women's automotive issues. We are fortunate to have had an automotive tech join us recently as co-host. Her name is Kristina and she posts under the ID md_tech. It's possible she may have even had some personal experience with this vehicle.
I don't mean to be chasing you all over Town Hall, I just wanted to be sure you were aware of all of the resources available here for your particular situation.
Meanwhile, we'll wait to see if anyone has any advice for you here in this topic.
Again, welcome. And good luck.
Pat
Kristina/co host Our Turn
* Brake problems about a year ago; major expenditure.
* Head gasket problem currently
* Air conditioner leak currently
Our Neon has about 83,000 miles on it. I don't think of this as high mileage, but apparently the folks at Chrysler do; when I told the dude at the 800 number the mileage, he made some comment about high mileage, and I shut him up by telling him about the Honda in my driveway with almost 200K on it that still works well!
At any rate, I could use advice, if anyone has any above and beyond what I've already read in the past 40-something gasket entries. I did call the 800 number for Chrysler, not really helpful, just referred me to the closest Dodge dealer in the area. Brought the car in for a "diagnosis" this morning, really more for them than me, since I'd already had the problem diagnosed by a local independent car repair place. They quoted me $700+ for the gasket, and 400+ for the air conditioner repair. The diagnosis slip didn't list auto part numbers or anything, just the total -- no breakdown of what the cost consisted of. Shoddy, in my opinion. Also, when my husband went to pick up the car (we opted not to pay for the repairs until we'd called back the 800 number) the repair person had left his half-empty gum pack on the driver's seat, and an empty can of chewing tobacco (!) on the passenger seat. About halfway home, hubby realized that the hood hadn't been closed tightly, either. When we called the service manager to complain we got "hey, it happens sometimes". So, we paid $70 for the diagnosis, and an additional mystery fee of $7 for "rags". Needless to say, Antwerpen Dodge in MD will not be getting any more business from us.
Called the 800# (which I about have memorized at this point) after that mess, and they called Antwerpen about it. Upshot was that the dealer would cover 20% of the repair cost. Big Deal. When we asked the Chrysler people about using a different (better) dealership, they said we'd have to start fresh with each dealer, meaning a new diagnosis, etc. I am so mad at this point, and I'm feeling really impotent and powerless.
It probably goes without saying that the new minivan we plan to buy in the next month WILL NOT be a Chrysler product. In the meantime, I'd love any additional advice you car-savvy people may have. Thanks!
