4x4 indicator light
djackson7348djackson7348 Member Posts: 1
edited April 2024 in Dodge
2001 ram 4x4 dash indicator light circuit has no power. Can anyone point me to the source/fuse? Thanks
  • thecardoc3thecardoc3 Member Posts: 5,860
    The dash indicator lamp shares input power to the instrument cluster with a number of other lamps. Fuses 17, 14, and 5 in the fuse box at the left end of the dash are shown as power inputs to the dash but the schematic does not show exactly which one of the three is the actual source for anything inside the instrument cluster. If all of the other lamps work then it's unlikely for it to be a fuse issue.
    The schematic does show that the 4x4 switch grounds the lamp.
