Having issues with the crank not turning after installing rod bearings in a 2.4l ecotech
I have a 2.4l ecotech engine in a 2017 Buick Verano. The head is off. I put in new pistons and rings new rod bearings in . No timing chains are hooked up. Just the number 1 & 4 piston rod bearings are connected to the crank. Before when there was nothing tightened to the crank. I could easily turn it by hand. After tightening the rod bearings for pistons 1 & 4 to spec 18 ft/pounds then 100 degrees. The crank wont turn now. Not even with a breaker bar. Which I didnt do too hard cause I shouldn't have to. I had to replace all the rod bearings that I put in the first time and the crank wouldn't turn. And I tried to force it and found out in doing so it scarred my rod bearings. So after putting in new rod bearing and tightening the rod bearings for piston 1 and 4. The crank wont turn. I don't have a clue at this point whats going. Anybody have an idea as to what is going on?
Did you measure the bearing clearance with plasti-gage? You would use the green as the specification is .0011~.0029 (basically 1-3 thousandths of an inch). A lot of people like to try to skip this step, but it is the builder's responsibility to ensure that everything is correct. The connecting rod journal of the crankshaft should measure 1.9291" ~ 1.9297". When you see that only the ten thousandths digit changes and that is only five ten-thousandths (5/10,000") you get an idea how precise everything has to be.
Let us know what the bearing clearance measures and if there was any debris between a bearing insert and the rod or rod cap.
The link below is for plasti-gage (.001"~.003"). Follow the instructions to use it. Let me know if you have any questions.
https://www.amazon.com/Powerbuilt-648441-Plastic-gauge/dp/B002INTX3C/ref=sr_1_2?crid=269ZJD8VDO6PV&dib=eyJ2IjoiMSJ9.-QxZXw4aXg0DlZ6yYlcr1gA9XsxIgC2GC5EfxzGIdfoZVImCPwO9A0nHgV4_FH_ERdn-DjI_MaB9EYLteEXvzdCF3ScLEo6W3KNAbDibC62qnEBD67rG5yiKu38kJrEj7ZvZbQeN3J9XiNtqBPk9YhztL8j2qlvTN6C_13WtL_BHxMTBDisWjowvwm3x7hmdDMdRgceVWwiIhLPELQgliIkMwCqTIT92eGnmXregG9o.-IrcO8yt2t3oPA3syWkH9nLS5PDawDU9kpqD-ghJAgA&dib_tag=se&keywords=plastigage&qid=1721340715&sprefix=plastigage,aps,84&sr=8-2
Here I have enlarged the package.
Here is a video showing the process.
