Error message 62TE: Should I be concerned?
deoCdeoC Member Posts: 2
edited August 2024 in Chrysler
Hi!
When I was driving through mountins with long and heavy slopes I got the following errors:
P0868 Line Pressure Low
P1790 Fault Immediately After Shift
In Germany, there is no support any more for the Lancia Voyager (Chrysler T&C).
Are these error critical?
Best,
deoC
  • thecardoc3thecardoc3 Member Posts: 5,860
    First thing to check is also the easiest, make sure that the transmission fluid level is correct. Has the problem since gone away or is it still occurring?
  • deoCdeoC Member Posts: 2
    Gone away. Need to order a special dip stick to meaure the oil. Will do so.
