Air conditioner isn't working correctly
hannahblue45hannahblue45 Member Posts: 1
edited August 2024 in Chrysler
hi everyone I'm having a problem with my 2010 Chrysler Sebring air conditioning. my problem is that no air blows out unless you kind of mess with the switch, but it quit working as of today. I think it might have something to do with the switch to turn the air on and off because it felt hard to turn the other day . the blower motor has been replaced but it has been quite awhile since that's been done.
  • thecardoc3thecardoc3 Member Posts: 5,852
    Anything like this needs to be tested to be accurate. There is always a chance that what you suspect, essentially because something feels different is accurate, but there is no way to know if there isn't something else in play and the switch just happens to be going bad too.
    Do you have any service information, especially wiring schematics and do you have tools to use for testing?
    If you do, I can walk you through the routine.
  • davidmalansdavidmalans Member Posts: 1
    edited August 2024
    It sounds like the issue with your 2010 Chrysler Sebring's air conditioning might be related to the switch or the climate control system. Since the blower motor has already been replaced, check if the switch is faulty or if there’s a loose connection in the wiring. It might also be worth having the climate control system inspected for any underlying issues.
  • sollanisollani Member Posts: 1
    edited September 2024
    Thanks, I also face this issue. You gave a great solution.
