radiator fan
I have a 1998 olds intrique gl. My high speed radiator fan setting does not come on. My low setting works fine. My A/C clutch went bad so I disconnected the electrical connection to it. My relays ,fuses,temp control sensor and fan motors all work fine. I can’t connect the electrical connection to the A/C clutch because it will most likely freeze up. When the temp sensor is disconnected my high speed fans turn on.
Why won't my high speed radiator fan work correctly?
Answers
