SUBARU ENGINE NOISE
Purchased 98 OB ltd june 98. When cold in fall
noticed piston slap on cold start. Contacted
dealer, they said normal for 2.5. After 8k took it
back to dealer and said i dont want it back till
noise is gone. next morn they called, said going to
replace short block. FINE!!!GO AHEAD. 7 working
days later was ready.All fine till winter
DAMN!!!!same noise. After taking it up with dealer
and reading the posts on this subject on various
forums, it must be typical subie, so just going to
drive it and hope for best. Making 3200 mile trip
in march------will report!!!!!!!
I even left it with the dealer over night so it would be good and cold in the morning and asked them to verify in a service report that the noise was indeed this lifter "issue" and not something else. When I went in to pick up the vehicle they said that they heard no noise.
Next week the Subaru factory rep. is going to be at my dealer and I am going to drop it off again so he can listen to it, but unless Subaru surprises me and changes there tune this will not only be my first Subaru, but my last. I know that every manufacturer has problems now and again, but I feel Subaru is denying a problem instead of addressing it. I love the versitality that the Forester gives me, but if Subaru is not going to stand behind it's product I am going somewhere else.
Geez, even GM did a better job to fixing the lemon S-10 I once owned. They didn't deny the problem, they actually FIXED it. What a concept!
I'll report back after I find out what the factory rep. has to say.
-Colin
Other have recommended running synthetic oil to "quiet" the problem, any opinions?
Thanks, Shane
(sorry I don't check this forum very often...)
-Colin
My dealer and the factory rep. were able to drive my Forester and that rep. said that the noise was from the pistons, and not the lifters. He also said he has heard worse. ( I guess that is suppose to make me feel better ?!? )
Anyway, he explained that the noise is a result of the piston skirts being shorter, and that no problems would occur because of this.
I am having a hard time agreeing with him.
However....
I just returned from Jackson, WY for a week of skiing ( This is the cause of the delay in my response. ) Added 2,800 miles to the odometer of my Forester. As luck would have it, there happens to be a Subaru dealer in Jackson, WY. I stopped in one day to discuss the noise with them. They agreed that the piston skirt was probably the problem and that it is common in the 97/98 2.5l engine. BUT... they also said if the piston in cylinder number 4 is replaced, the noise should go away. Hhhmmmm!!! The Service Manager at my dealer and I are going to have a very serious discussion in the next few days about this.
I'll let you all know what happens.
P.S. The Subaru performed great on the trip. But of course we all knew that it would. As I stated in a earlier posting, I love the versatility that the Forester gives me. It can haul and/or tow everything that I need it to, but I also can't help but feel ignored by my dealer and SOA too. To bad there isn't another Subaru dealer close by ( at least 75-100 miles away ) who would do a better job of taking care of my needs and stepping up to the plate with SOA for me.
When it comes time for me to trade in my 98 ( this summer ) I will probably consider Subaru again, but I will seek out a different dealer. Factory rep. also said that the redesigned single cam 99 and up engine has a different piston design and that the this issue does not exist. Maybe this won't be my last Subaru.
-Colin
He said, and I quote, "Hhmmmm".
I told him that he WOULD dig further into this for me and and produce something in writing from SOA either confirming of denying this. He said that he would see what he could do.
It really doesn't matter now though, because the next day I traded-in my Subaru for an Toyota Tacoma Extra-cab 4x4. I'm going to miss my Subaru, and I will buy one again someday, but not from my current dealer.
Ivan
I haven't gone digging on the NHTSA site for a recall / TSB, but it wouldn't surprise me if there is one.
-Colin
I own a 99 Outback with the 2.5 DOHC solid lifter engine and I have heard no engine noise except from the exhaust which I really like. The sound of this engine reminds me of the V8's of my youth. I have even thought of installing dual exhaust to further exploit the sound, but it appears that no after market kit exists, too bad because the engine design lends itself very well to a dual exhaust. If you look underneath, you see that there is no exhaust manifold (header), the exhaust pipe mounts directly to the bottom of the engine, on both sides, so the engine exhaust is already split, like a V6 or V8. I would like to learn more about this engine and drive train but manuals from HELM'S Inc. are not available. I guess I will have to wait until 2003 to get a manual from Chilton's.
The 99 and later 2.5L engines changed from 2 cams per head to 1 but still have 4 valves per cylinder. All of the Subaru engines that I am aware of use a timing belt(s) rather than a chain. The dealer told me that the tensioner operates from oil pressure and that mine had slop in it that caused the noise. The noise has not come back in the month that we've had it back but it hasn't been real cold yet either. Before it was fixed, the noise seemed to be a function of how long the engine had set rather than how cold it was. Time will tell.
Just last week, my wife got too friendly with the rear end of a 2000 Chevy Cavalier. The Subi is still drivable but kind of munched in front. The brushguard seemed to take the brunt of the damage. When it collapsed back, it took out the grill and the front edge of the hood. The Chevy had a trailer hitch which punched a hole in my front license plate. Looking forward to getting it fixed since it is not even 6 months old with less than 6000 miles on it. The damage didn't get past the grill so didn't get the A/C or radiator. Still the damage came to nearly $1800 while the Chevy got off with less than $600. I suspect that the trailer hitch may have had something to do with that also.
Ivan
Maybe now the piston slap problem does not seem
so significant,(just kidding).
Hope it gets repaired to your satisfaction.
My 99 outback has the dual cam configuration.
I bought it in July of 99, just before the 2000's
came out. I think the single cam configuration
came out with the 2000 models.
Sugardog.
Also 99 and up models receive the more tuned Phase II engine which saw an increase in hp and torque.
The Legacy and Outback went to Phase II in '00.
-Colin
tc
This conference deals with maintenance or repair issues of already purchased vehicles. I found a topic in our Station Wagons Conference that looks like a perfect place to post your question. Here is a link: The Impreza Outback Sport: Experiences and Opinions.
If you'd like, you can use the Topic Search feature on the left side of this page for Impreza to easily find other topics that may be of interest to you.
Good luck, and again welcome.
Pat
