Lubricating BallJoints, UJoints and Bearings
Well, my new 2000 Dakota has no zerk fittings.
How do you replenish and purge old grease?
Is there a way to tap in a zerk fitting into the
upper and lower fittings and the steering knuckles?
For a nipple on a drive shaft u-joint, pump grease until you can see it coming out around the u-joint. If your blazer is the small one (like an S-10)with 4x4 and a skid plate under the front end, it can be extremely hard to grease. The skid plate makes it almost impossible to get to some grease fittings. If I remember correctly, there should be a total of 11 fittings for the front end, plus possibly more for the drive shafts.
and would like to know if there are more than 6
fittings on front end. truck has rack and pin.
any answers would be appreciated.
red
in the event you missed this discussion over on the silverado page...there are 11 zerks on the front end of a '00 1500 LS Z71
to see 10 of them, go to:
http://www.PictureTrail.com/kwerking/95343
# 11 is on the passenger side, and is really hard to locate unless you remove the plastic brush guard (5 15 mm bolts). i'll have pics of all 11 posted on that trail before too long...gotta get the truck up in the air first.
#5 passenger side i had to replace with a right angle zerk in order to get to it. again...easier to do if you remove the plastic brush guard.
kyle
Is this common on the S-series trucks? Why? I've never had such short a lifespan of front end components on my previously-owned vehicles. Is it a design problem?
GET A SECOND SHOP TO LOOK AT THEM!!
I knew of one shop that sold LOTS of U-Joints simply by grabbing the driveshaft and wiggling it. Of course, there is slack in most drivelines, so the car owner would see and hear a little movement. Bingo,,,,2-3 new u-joints that were never needed. (The shop was fined for this eventually).
