changing transmission oil bad?
Hello!
I have a 109K Mazda 626, just bought, and want to
change the transmission oil. I read in a book that
this can make things worse, create new leaks. That
it's better to wait until the transmission is ready
for an overhaul before changing the oil. I'd
appreciate any advice on this.
Bo in Miami
Bo in Miami
Age, contamination, and heat cycles are what damage seals. New fluid into a flushed tranny is your best bet for continuing the life of that tranny.
At any rate, it is often said that transmission failure is the result of overheating, however, the ROOT CAUSE is typically fluid loss through a cracked hose or rusted-out line (my Taurus!) or a leaking gasket. So if replacing atf shows where the leaks are, that's actually a good thing because then you can see which hoses, gaskets, etc. need to be replaced. My 2 cents. R.D.
Dilemmas, dilemmas !
My experience with pan gasket (leaks)... I typically use Fel-Pro gaskets (not cork); usually I have to re-torque (criss-cross pattern) the pan gasket bolts after a few heat cycles. Otherwise, I develop a small leak, since the gasket takes a heat set. Once I re-torque them, no leaks until i change it again (30K mileage intervals).
So I never knew I had to change it until the car had 100k. At 100k, I brought it in for service, and my mechanic/friend told me "if it's never been changed until now, don't change it". So I didn't and the car's tranny was fine right until the original timing belt broke at 161k.
My friend had a Mitsubishi Starion with 96k, he changed the tranny fluid even though the tranny was fine, and the tranny was roasted at 98k. My advice- if it ain't broke, don't fix it (except with timing belts)....
The myth about changing fluid on a high miler and then having a catastrophic failure is exactly that, a myth. Usually traceable to pure coincidence (Murphy is a mechanic) or the fact that the trans was on it's last legs anyway and the owner was trying to Band-Aid it.
On day I picked up the truck I drove three miles and stopped for a meal. After eating I checked the fluid level it was about two inchs above the cross hatch area. Returning to the shop right away I asked the service tech to verify level. He said it`s a little high but O.K.
Three weeks later I was heading out on a long trip so I stopped by the shop for a level check. The service advisor said it`s about a half pint low.
He found a funnel about 3 feet long which ended up jammed against my under hood mat. He held the funnel with one hand and picked up a 2 gallon plastic container of fluid and glug glug into the funnel. As he sat down the plastic container the funnel fell spilling fluid across my battery and A.C. hoses. Again he picked up the funnel and can and glug glug - more fluid into the funnel. He again checked the level and said your good to go.
About three days after my long trip I noticed pink fluid on my driveway. I checked the fluid level and it was about 4 inchs above the top of the cross hatch hot fill area. It was checked on level ground - in park and with a hot engine.
Question is can an overfill cause my rear seal to leak. It now drips after every trip. I see red fluid on the first drive shaft section past the transmission. The service guy at Glen Burnie Transmission said it`s just draining out a pressure relief valve and this is O.K. Paid them $1,700 for this work.
Any Comments?
Don.
Should the transmission rebuild shop have checked the rear seal and rear bushing/slip yoke when doing a $1700 rebuild job or is this something I should not expect them to do?
These extended service intervals are really misleading and I don't trust them;just don't want to be so plugged up about it that I cause harm to my vehicle.Wtd;I think changing trans fluid as often as your motor oil is probably too often even for my neurotic tendencies!Ha,thanks for the advice, both of you. Dave
