First, what to use when washing the vehicle? Lamb's wool? Sponge? Rag? I am spooked about scratching or putting swirls in it.
Second, claying . . . I've never used clay before or done it and frankly am scared to death. Sal told me I should clay right away, even on a brand new finish. Any advice/tips? I really would like to know how EXACTLY to clay my vehicle.
Beyond that, I might have some more questions, but for now, that's it.
"Second, claying . . . I've never used clay before or done it and frankly am scared to death. Sal told me I should clay right away, even on a brand new finish. Any advice/tips?"
Read the Zaino website directions, faq, tips, etc..
Use back and forth motions, keep areas being clayed well lubricated(use 1-2 capfuls of Z7 mixed with water in a large spray bottle). Throw out clay if it is dropped on ground, knead the clay a few times while using it to expose clean surface. Clay does take some work but is worth doing.
As far as clay being overkill it really depends on the surface. Before using it I would take a good hard look at the finish looking for rail dust and industrial fallout. You may need to use a magnifying glass as some colors hide the filings better than others. If your surface is as smooth as you like and there is nothing for the clay to remove, then by all means skip the claying step.
As for claying, I took delivery of my brilliant silver MB last April after the dealer did an excellent job of detailing it. The finish was gorgeous and super-smooth. I did not clay, but I immediately did the blue Dawn wash, Z-1 and Z-2 and have added numerous additional coats of Z-2, plus one more Z-1/Z-2 a month or two ago. I also frequently use Z-6. The car is garaged and washed regularly, and the paint is still super-smooth!
And if I ever used a magnifying glass to check for contaminants on the finish, I'm sure my wife would have me committed! Bottom line: I'm happy as a clam with the shine and the durability of Zaino. I'm regularly asked what I use on the car to keep the deep "wet look" reflectiveness of the metallic paint.
BTW, if ever I acquire a car with a dark colored finish, I'd almost certainly clay to prepare the surface for Zaino. I'm not real anti-clay -- just a bit lazy!
Anybody got any info to explain why clay is better than wax for smoothing the surface?
I only use Z6 after washing the car. There's enough construction going on around here that there isn't any other way to get all the dust off before putting Z6 on.
Z2 is the really glossy product - Z5 has some, but it is designed more as a "swirl remover". It still shines nicely, but you should see the dramatic results after a coat or two of Z2.
re: Small Bumps: On a new car? That has to be a manufacturing defect worthy of Dealer fixup or intervention of some kind. The give away here is that there are raised areas below the paint. The sheet metal surface was defective prior to painting at the factory. Or at least that is what your posting seems to indicate. Let us know what the dealer says.
I think Grott's sells a similar one.
Also, use the California water blade for drying and touch-up with the famous white 100% cotton USA towel. Again, super fast and seems to leave the surface perfect!
I have painted alloy wheels that looks like a silver metallic paint('01 Camaro) and wonder what the best protection is against brake dust.
In my case, I had the Easter long-weekend + one day off to apply. I generally waited approximately 12 hours between coats. In some Zaino tips which I printed out last year, it indicates that if you apply the Zaino the night before, and leave it on over night, you can wipe off in the morning and immediately re-apply. This is what I did with every coat. I applied early am (ie. 8 or 9 am), left the Z on all day, then wiped-off after my son went to bed (ie around 9 pm) and re-applied another coat and left it on 'till next morning. Note that my garage is extremely clean, about 22 feet wide by 27 feet long allowing plenty of space to work, and is heated. Humidity was relatively low. Needless to say, my Outback sat in my garage for a few days.
Results: FANTASTIC!!! Wet look is amazing...many people have commented. Time will tell if I applied too quickly...ie by how long the shine/wet look lasts. If so....I'll just apply another coat. With the claying out the way....another coat is a breeze.
PS. Just picked up a California water blade to save drying time. I know some of you take it for a spin around the block, but that would leave spots with the dust from new home construction around my house.
Luck11.
Sal's email address is sal@zainobros.com
fastdriver
http://y42.photos.yahoo.com/fastdriver2_99
Robert
koury - give it a try. I may try the alcohol and SSS on my alloys. They have brown tar and brake dust marks I can't clay because my rims are textured. I don't think either could hurt the alloys/clear coat - after all you use the stuff on your body.
Good Luck
I am also considering claying...the steps are Dawn, Clay, Z7, Z1, Z2 right?
Tax
Does anyone know anything about Ardex - the detailer claims its "the best" and only professionals use it (cannot be bought by individuals in a store or otherwise).
Thx
http://www.autoaccents.qpg.com/
They're kinda like Pro and other suppliers who sell mostly to car washes and detail shops. It's not consumer stuff.
Thanks for any help you offer.
The newer invisible bras are much better than the old black/cloth ones IMHO; e.g., in the Northeast, you have to take norman bras off in the winter when they sand the roads like crazy..just when you need it the most :-P
The only negative I know of is that they are too expensive because they're very labor intensive...
In the end, they all use the same 3M developed material.
