Visitor Agreement.
Z6 is like your typical QD - best used to lightly clean the car, removing fingerprints, light dust, bird doo, etc. It leaves a nice shine but doesn't last.
Z8 is not as good a cleaner as Z6 but leaves a glossier shine and will last longer on the paint.
Two similar products that are designed to do different things. I use Z8 after every wash and now only use Z6 for light cleaning and wipe downs.
Thanks in advance!
Regarding Dawn Blue, I feel it's wise to use Dawn as the first wash when the vehicle is clayed and polished every 6 months. Follow up with a 2nd wash using Zaino's car wash soap, then proceed to the applying the polishes.
If you're not interested in claying the vehicle, using Dawn for the first wash will do the "heavy lifting" of surface contaminants. After washing with Dawn, no need to dry the vehicle-- just wash it a 2nd time with Zaino's car wash soap, then dry the vehicle and proceed with applying the polishes.
For those who may be leary of using the claybars, I would urge you to give them a try, because the results are simply amazing. However, make no mistake-- if you have a light colored vehicle in which brake dust and other hard-to-remove contaminants are visible and embedded in the clearcoat, the claybar is the best and maybe the only way to remove this stuff, but it will require plenty of elbow grease. I own a white SUV, and I find claying to be hard work. Look at it as being not only a good aerobic workout, but also one of the best things you can do for your vehicle's finish.
As for PC's, Lowes sells the 7336 for $109 but you need a backing plate and pads to go with it. Autogeek is selling a nice PC kit with all the basic accessories. Detailers Paradise also sells a nice kit. Both kits are in the $170-200 range.
At the very least you want a polishing pad and a finishing pad. The polishing pad is more aggressive and will help remove swirls, scratches, etc. The finishing pad is good for mild cleaners and polishes, even Z2 or Z5 use.
Buying a PC kit is a good value for beginners. A couple nice kits are, link title
And this one: link title
All you need from here are a couple of polishes and you'll be ready to work.
Hope all this helps!
Knowing what pad to use is part of the "art" of polishing paint. You have several variables at work; pad aggressiveness, polish aggressiveness, polisher speed, polisher pressure, and the amount of time you work the paint. Throw in paint condition and hardness/softness, and its a challenge to know exactly what combo is best for a particular situation.
My advice for beginners is to buy a few polishes and pads and learn how to use the machine properly, then expand your pad and polish inventory if you want. The kits I linked are great for starters because they include the basics.
If you just want a couple of pads to start with, check out your local auto body supply stores for Meguiar's pads. I use them a lot and get great results. Meguiar's offers only 3 pad types so it's real simple - maroon color for cutting (most aggressive), yellow for polishing (sort of an all purpose pad), and white for finishing (use with light polishes and liquid waxes). A couple yellow pads and one or two whites will be fine for starters. Meguiar's pads usually run $10-15 each.
Coastal Tool offers a nice basic PC kit, if you don't want all the pads the other kits offer. Coastal Tool PC Bonus Kit
I bought my PC from Coastal; their service is excellent. So, $120 for the Coastal kit plus maybe $30-40 for new pads and $20-30 for some polishes.....$200 should get you started polishing with no probs.
Let me know if you have more questions.
I'll be ordering the PC today based on your recommendation.
The LS will prolly need some pretty aggressive polishing in order to remove all the swirls and bring out the shine. What polishes do you have or are you buying beside Z-PC?
Have fun with the PC!
Thanks for all the help!
The difference is that wax typically breaks down faster than a polymer and needs more reapplication.
For example, because carnauba is a natural product, it is very prone to oxidation and yellowing. And, like most any natural wax, carnauba will readily become either soft or brittle (eventually cracking) under the thermal stresses of seasonal weather conditions. Furthermore, natural wax forms only a very weak electrostatic attraction to an automotive finish, and it is therefore rather easily attacked and removed by everything from road-borne oils to automated car wash detergents. Also, natural wax is easily attacked by such common things as acid rain, bird droppings, tree sap, and gasoline dribbles at the fuel tank spout.
Because carnauba wax oxidizes, yellows, and softens over time, the old wax should be stripped off of the finish before a vehicle is rewaxed with a fresh application of carnauba. And, because automotive carnauba wax is a natural product, its shelf-life is rather limited, and old bottles or cans of this stuff sitting around in a garage, are prone to eventual chemical separation, oxidation, chemical breakdown, rancidity, etc.
On the other hand, excellent synthetic polymer, automotive polishes such as those made by Zaino, are superior to wax in every respect, although they do cost more than the archaic carnauba wax products. When used correctly, Zaino products (1) form an amazingly strong and highly protective bond with the underlying finish; (2) they greatly resist most environmental stresses with ease; (3) they do not require stripping between successive applications of Zaino polishes; (4) they have more extended shelf-lives.
Can't I think of Zaino as another lay of protectant? What are the "issues/harm/disadvantage" of applying Zaino on top of wax?
If you are going to Z, take the time to strip the wax off by washing with Dawn dishwashing liquid and then apply the Z to the paint directly.
On a tangent, I have a paint sealant called "Touch of Class" from a company called
Cal-Tex Protective Coatings, Inc.. Anyone have any thoughts on apply Zaino on top of that sealant. I don't know all the details of that products (ie whether dawn will take that off).
These paint sealant products often include a variety of enticing claims, and they also often include a bottle of some type of rejuvinator or other such product claimed to restore and rejuvinate the sealant when applied every so often. When you run out of the rejuvinator, your dealer will surely be happy to sell you more.
My suggestion would be to figure out how to safely and completely remove the sealant if possible, then proceed with "Zaino'ing" the vehicle at your earliest convenience. If in doubt, contact Sal Zaino for advice before proceeding. Sal is very good about returning phone calls and emails, so don't hesitate to give him a shout if you have lingering questions and concerns.
Here's what I did:
1) PC with the ORANGE pad and the Meguire's
2) PC with the WHITE pad and the Z-PC.
Should I have used a more aggressive pad with the paint cleaner? At one point I had it up to around 5 on the dial, but I think that may be too high. Any thoughts?
It's kinda hard to say which combination will deliver the results you want. You've got to test various products and pads to see what works best. Send me an email at "bretfraz@excite.com" and I'll mail you a couple samples of more aggressive polishes. Maybe one of them might be just what you need.
The PC takes some practice to master and every polish and pad combo has its own sweet spot, if you will. Personally I polish at 6 or close to it but use the machine where you're most comfortable.
Also, can I use plain water as a lubricant? Water with a little car wash mixed in?
I'm actually responding to your post in the Non-Zaino forum as since you're not supposed to discuss Zaino over there...
I recognize you from the TL forums. I have an '05 Abyss Blue TL and just recently became a convert to Zaino. It really is great. I can't answer your clay bar question, but depending on the depth of your swirlies, Zaino Z5/ZFX might do the trick. I put two coats of Z5 on my TL followed by two coats of Z2. I appear to have no swirlies and some minor scratches, while not completely gone, have been reduced nicely by the Z5. Maybe a couple more coats of Z5 will take care of 'em.
Anyway, ordering from zainostore.com is easy and they email you the progress of your order. If you haven't, you should check out the website.
It's a bit of time to do multiple coats, but my car looks GOOD!!!
Thanks for your insights.
My suggestion is to buy clay based on price or favored vendor. Zaino clay works very well (as do many others) so if you prefer buying from Zaino, go for it.
At retail the two major brands are Clay Magic and Mothers. Both are excellent products and are good choices if you don't want to mail order clay.
The labels aren't exactly chock full of data and details. I don't have my Z with me, but IIRC there's nothing on the label that's not on the website.
Yes, it is recommended to use Z6 before you apply Z2 or Z5 to "lock in" enhanced gloss (and aid in ease of application, I believe). For my first order, I bought ZFX, Z2, Z5 and Z6. You can also use Z6 after washing to ehnance the gloss. I think it works, especially for darker colors like ours.
As yours is an '04, you may want to clay but it's not mandatory. And start with Z5 to deal with the swirlies. Use Dawn dishwash to wash/strip all old waxes and go to Zaino town!
If you decide to go this route, let us know what you think after you Zaino.
The PC really excels at thin applications of product but the same can be done by hand, too. I guess the PC's advantage is in saving your arms and wrists, just like while polishing.
Anyway, there is ample salt use on the icy roads in winter here. I am considering running the cars through an automatic touchless car wash of good quality, esp. to get rid of the salt/sand build-up in the undercarriage. On the 2006 Infiniti M35/45 discussion thread, there was a post about such a car wash having ruined a BMW finish protected by a Liquid Glass product.
Has anybody had a similar experience with a Zaino'ed car? Will it be safe to run my cars through a touchless car wash several times in winter, and re-apply fresh Z2 coats in the spring (of course, after the mandatory Z7 hand wash)?
It does take some time to properly "Zaino" your car so you may have to find a friend in the 'burbs who has a hose and a driveway you can use for a bit...
Most high quality waxes or sealants look good on black and red. But its colors like silver and beige that are a true test. I don't know of a more reflective product than Zaino Z2 Pro. It'll not only make the metallic flakes pop but it will bring out the best possible gloss in silver.
When I lived in downtown Chicago (111 E. Chestnut & 441 E. Erie), I used to drive out to Arlington Hts/Buffalo Grove to hand wash my car once a week at a real nice coin-op place. I'd either drive it back to my parking garage to polish & wax or do the work at the car wash. I was always able to find a power plug in the garage for my buffer and shop vac. But I like the "friend in the suburbs" idea even better. A full on detail only needs to be done a couple times per year; you can do regular maintenance at your place the rest of the time. Big City car care is a challenge but its not impossible. I did it for about 5 years.
I park my '04 Acura TL in a garage that leaks rusty water (picked up from the re-bar I would guess). This has left spots on my car that do not come out when washed in a car wash or even by hand. :mad:
I mentioned this to my apartment manager (I wanted him to pay for a detailing) and he told me Fantastik brand cleaner would do the trick. Will this damage my clear coat?
He also told me NOT to use Fantastik on German cars as their clear coat and paint are softer. :surprise:
Any thoughts would be appreciated.
Thanks for any input.
