A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Maxima 2000 automatic A/C
I just bought a fully loaded 2000 SE. I love it,
it is fast, handles like a dream, and has room for
my growing family. I am experiencing a problem
with the automatic A/C. when I set it on auto and
recycle, at 65 degrees, it is ICE COLD. however,
the moment I increase the temperature control to
66, 67, 68, 69, or 70, it seems like the A/C is
trying to heat the car up. In fact, I feel hot
air. I spoke to the service department who said
that is was just part of the way these cars were
made. If I want it cold, keep it at 60 and if it
gets too much, manually adjust the fan speed. I
can't believe I spent so much money on a car in
which the A/C settings don't work as expected.
ANY THOUGHTS, SIMILAR EXPERIENCE........ THANKS
to 60 where the max only goes down to 65. I guess they made it so that 65 and hitting auto is the only way to work the A/C. Every other car has an A/C button to hit that turns on the A/C, even with climate control where we have to hit econ if we want 65 degree wind that isn't cold. Definetly not the standard A/C system but it does work once you get used to it.
the two center vents are consistantly cold, ice cold when I want, however, the two side vents are at least 10 to 15 degrees warmer.
so when I set it to 66, it is warm in the car. I measure the center vents and they are 66 to 67, but the side vents are almost 80............
moreover, if I close the side vents, then the warm air is transfered to the center........
I am taking her in for a check-up
NDS
Sorry.
NDS
If you could provide the topic #, I'm sure nds1 would appreciate the help...
Your host, Bruce.
Maxima 5-speed Problems
or Brake
Pat
