Bad rotors on 1999 Oldsmobile Alero
                    I've been driving for 21 years.  Mazda 626 & MX6,
Nissan Stanza, Ford Pinto, Chevrolet Vega & Honda
Accord. Each time, I drove the cars in excess of
60k miles. In the case of my Ford and Chevy, I had
an excess of 80k miles on each of them. This is the
FIRST time I've had to deal with the issue of
warped rotors. And to add insult to injury, my car
has 20k miles on it!
The problem began at 17k miles, but the dealer
couldn't "find" anything! Luckily, from reading
reader responses in the Town Hall, others have
complained. I took the car to the dealer today,
and they have to replace the front brakes and
rotate the rotors. Since I'm at 20k miles, the
dealer said the cost is on me!
This has got to be a design/manufacturer flaw,
woulnd't you think?. What's the next step to
filing a formal complaint? I can't believe this is
my fault and I can't believe that Oldsmobile isn't
doing a recall or something. Can anyone help me?
after i had the dealer change the rear rotors, i stopped using the e-brake when parking the car with my auto tranny. so far, so good. never any problems with front rotors though.
you shouldn't pay to have them replaced. rotors are warrantied as long as the engine, i think. pads are not but i did pay for my brake inspection after she crossed 10k km. i don't think i should have even paid that. everything else was free, under warranty.
yofa - yofa42@hotmail.com
I need to know more about this. What is a brake rotor. How much does it cost to replave them?
Is there any maintenance possible?
I've noticed that many of you have been experiencing brake rotor problems. I can't speak for other brands, but in the case of GM cars, like the Olds Alero, I do have some insight for y'all... I currently own a '92 Pontiac Grand Prix sedan, and my dad previously owned a '93 Grand Prix sedan. Both cars had REAR brake rotor problems. Here's my versions of WHAT and WHY:
Firstly, WHAT problems?
Well, the rear brake rotors would tend to get rough, creating a rear brake chatter, which would consequently lead to uneven brake pad wear such that the two uneven surfaces may rub and make minor squeaking noises while driving. (Although only noticeable at low speeds with the window down for me.) I've LET this problem progress to the point that the rear brake pads and rotors were so rough (and shot) that they caused some kickback, which was noticeable at the brake pedal under braking. Note again, that I let them get this severe by letting it go until there was hardly any brake pads left, literally. Nevertheless, some of you may be familiar with the brake chatter and other consequences of having uneven (not smooth) brake pads and rotors in the REAR. I know myself that sometimes it SEEMS like the brake problems are being caused by the front brakes, but it is the rear brake rotors causing the problem. I've noticed this, and so has my dad, who learned the hard way--the first time he encountered this problem he thought it was the front brakes; so, he changed them, only to find it didn't solve the problem. It was only when he changed the rears that the problem was fixed. Indeed, once I encountered the same problem on my Grand Prix, bought later, used, did I think I had a problem with my front brakes, only to be told by my dad that it was really the rears. Guess what, dad knew best. Fixing the rear brakes only did solve the problem. Therefore, at least GM seems to have a problem with their REAR DISC BRAKES.
WHY?
Here's what I have gathered as to why this problem happens... A car does 80% of its braking using the front brakes, meaning the rear brakes only account for 20% of its braking. So, the rear brakes aren't used for much of the braking to begin with, PLUS look at the size of the brake pads on the front and the back disc brakes. The rear brake pads are almost as large as the front brake pads, yet remember, the rear pads aren't being used as much as fronts are. So what? Well, for forward driving the rear brake pads are really too big than they need to be, such that they aren't applying (squeezing with) as much pressure to the brake rotor as the front ones are. Fine, except for one more tidbit: Brake rotors, over time will rust and wear. As the rotors wear, the pressure that the front brake pads put on the front rotors is usually enough to rub away any imperfections on the surfaces of the front rotors, thereby keeping them smooth and trouble-free. However, because the rear brakes aren't used as much, the imperfections, like roughness, flakey rust, etc. won't get completed rubbed away by the rear brake pads. In fact, they'll probably get worse as time goes by, meaning you'll end up with rough rear brake rotors and unevenly worn rear brake pads to match them. In the end, the quality, AT LEAST in sound, will suck from your rear disc brakes.
What can you do?
Well, this problem regarding rear brakes is only found in GM cars like the early '90's mid-sized cars featuring REAR DISC BRAKES. If you have REAR DRUM BRAKES, then you will never have these problems. In the case of the new Olds Alero, all Aleros feature rear disc brakes, while its Pontiac kin, the new Grand Am avoids the these problems by offering rear drum brakes in all its models EXCEPT the GT models, which have disc brakes in the back. The catch is this: For braking purposes, REAR DISC BRAKES are better and when smooth offer better braking feel at the brake pedal than REAR DRUM BRAKES do. Yet, if you are encountering problems with your rear disc brakes, these advantages may account for nil versus rear drum brakes. So the choice is yours here. BUT surely SOME MANUFACTURER MUST have REAR DISC BRAKES that are as trouble-free as front disc brakes; so, why can't GM (and whoever else has cars with this problem)?
Secondly, I'll tell you one way I've heard of to try and keep rear disc brakes smooth and free of imperfections like the fronts... every once in awhile when you're in your driveway or somewhere safe, stop and PARTIALLY engage the parking brake. The parking brake only engages the rear disc brakes on front wheel drive cars; so, with a front wheel drive car you can then start to drive SLOWLY with your parking brake partially engaged. Don't leave your driveway, because you should never drive with your parking brake engaged, partially or not, but just enough so that you'll get that extra pressure on your rear disc brakes to rub off any roughness that may be beginning to form on your rears. Thus, this should keep them smoother, longer. Just remember to disengage your parking brake after your 30sec in-house clean up.
Thirdly, you can also take off your rear tires and use a chiselled hammer to chip off the rust that accumulates on the rear brake rotors to keep them smooth. The inner side is difficult to get at though, while still on the automobile.
Hopes this helps.
I have drive my 99 Alero GLS for about 27,000km. I notice that when I apply the break, vibration can be felt. I had notice this issue before, and taken my vehicle back to the dealer for repair at about 10,000km. I believe they have grinded the rotor to resolve the problem then. I would like GM to tell me if there is a perminate fix. As this problem with the brake may be protentially dangerous. Please advise me of the corrective actions, and tell me if the warrenty cover this type of problems. If you follow the site provided below, you will find other complaining of the same issue. Thank You...
http://townhall-talk.edmunds.com/engaged/edmund.cgi?c=Maintenance&t=1236
*NOTE : This letter will be copied to the Auto web site to assist other customers.
I did think it odd that this would happen so quickly, but that maybe my problem was a freak occurrence. Now I know better. If the rotors do this again, I'll be demanding new rotors, not machined ones, and I'll take all these posts along with me.
Thanks for the information....
FYI, check the Malibu section, seems to have a lot more complaints about the brakes.
I have 2 posts about my horrible problems, and the fnial one may have a solution for most owners.
With the Malibu's, the front brakes are undersized, causing the front brakes to just get eaten at an insane rate. This seems to be a common problem with GM, as of late, at least.
My mechanic services a fleet of Malibu's, and ended up solving the problem by using heavy duty pads with a ceramic compound as a base. These are commonly used bu ambulance and cab fleets
All these theories that the rotors are bad or defective are most likely wrong.
Your front brakes should be larger than the rears, assuming the rears are even properly sized.
Best option is to pass the word, and find another brand when you decide to buy again.
BTW, my entire bill for the job will be about $145, and thats for resurfacing rotors, news pads, and labor. That is a deal as far as I can tell, at least out here in CA where the hourly rate is $60/hr.
Best of luck.
Brad
Western Pa.
It all really depends on who you go to. There's another dealer locally that when I asked them at the 15K mark about warped rotors, said that I would be responsible for the costs. Then I decided to go to one near my work and they've been doign a really good job.
On another note, have any of you had problems with the fuel tank guage? My sensor went berserk after 6 months and was replaced. Now they have to replace another one. Just wondering.
Also the door runoff molding on my car started to warp too. Maybe because of the hot sun in Caliornia? But anyways, they had to replace those today as well.
Overall, I've had nothing but fun driving my car. I have to admit that I am a very aggressive driver and will and have taken my car to the limit. And so far, the car handles great (but I would like to find some stiffer srpings for it) and the power is great (although a nice supercharger woudl be good too). Hey what can I say, I'm a speed freak.
Well I would like to hear whatever responses you guys may have had to my problems as well as sharing your own.
My wife now drives a '98 Intrigue. It was an early build in the initial year the car was offered. Got about every imaginable option except chrome wheels. Sunroof, leather, Autobahn package, CD player, etc. Again, overall a decent car but not outstanding. Bad fit and finish in the interior, lots of broken plastic parts, intermediate half-shaft replaced, etc. Interestingly though, it still has its original brakes. I'm convinced that there is something wrong with them, my wife has no complaints. Since I drive the car once every two months I'm going to butt out.
Now, the '90 Olds needs to be replaced and the lease is up on the Intrigue at the end of August. Wife and son were thinking of 2 Aleros or an Alero and an Intrigue. Given the comments on this list and over on the Intrigue list I'm having some serious second thoughts about the wisdom of that action.
Now, the next thing is, I have received a recall notice for my Alero, with recall#036 on the code. One can not help but wonder what are the other 35? Does anyone know where to find them. I know that it is a standard industrial practice for car manufacture not to notify clients of minor problems until we compliant...
I would not doubt, although I have no information to support it, that the problem on the newer Aleros, Malibus, Cutlasses and Grand Ams likely stems from the same issue as noted above.
The solution? The W body car owners/lessee have already gotten, or will get soon, a response on the class action suit. The others will likely have to form their own class in order to get GM to address the issue. Good luck.
I imagine that I'll be getting myself added to the backorder list. I've been ignoring my warped rotors for the last 3000-4000 miles as I have not really heard of a true solution. Replacing the parts with the same quality really makes no difference if there is a flaw in the design, which it sound like there is.
What is feel is bizarre with my rotors is sometimes I can really feel them shake when braking, and other times after a longer trip I barely notice the shaking. Can we say "easily warped?"
Michael Wilson
Being a person that doesn't like going back to the dealer, I'll search the aftermarket (NAPA, Pep Boys) for replacement rotors and pads. I know the dealer will cut them for free, but the aggravation of taking it back to the dealer isn't worth it. Besides, I don't believe in cutting rotors, they only warp faster.
Has anyone checked the lug nut torque? I know overtightened lug nuts warp rotors real fast.
The TSB has the dealers replacing rotors and pads, not just pads and cutting rotors. My dealer expects the replacement rotors and pads next week.
Both cars are/were great, except for the brakes.
On the Blazer, at 8,500m, the front brakes were so badly worn the pads and discs had to be replaced, and on checking the service log, I discovered they had also been replaced at 1,500m (1,500 miles!) before I received the vehicle.
The pads had to be replaced again at 17,000m - this seemed extreme, so I checked with GM who said there were no problems, must be my driving technique.
I admittedly drive fairly aggressively, but three pad, and two disc, replacements in 17,000 miles?
Now on the Alero, I have 12,000m on the clock, and again there is shudder from the front brakes, and under little or no pressure, the steering wheel shakes from side to side. Then two days ago, without any warning (no shrill whistle warning of brake pad wear), the front right brake started making an ominous grinding noise. Looks like a trip to the dealer tomorrow.
Anyhow, just wanted to check in with my experiences with GM cars and their brakes. Will update on what the dealer has to say tomorrow. But in the meantime, thanks for the postings on these problems - at least I have a starting point for tomorrow.
They suggested front rotors and pads need replacing, along with a tire rotation and wheel alignment for $836.
Got the usual BS about driving styles, and was told warranty was not in force at 12,326m (warranty on brakes is apparantly 12,000m/12months)
Stood my ground, mentioned the conversation here on Edmunds.com, and guess what - they are now doing the work for free, "because I am a long standing customer".
Good luck with your Alero's brakes, and thanks for the postings - they helped me.
They do have well paid executives making millions while you keep buying.
THX
As for the temp guage, mine sits just below the half-way point until about 40 mins of driving where it will rise to half way. It's only passed there when idling my car overheated (don't worry, no biggie, it was a faulty seal on the coolant cap, fixed under warranty)
For the pulsation, I've only noticed it when slowing down from highway speeds, never in stop and go traffic. But, GM is slowly replacing the rotors and pads on the Alero so you might want to book an appointment if you're worried about it. Although they are seriously backordered nationwide. I've currently waited 2 weeks without a call so far. Hopefully they will be in soon.
But, in any case, I still love the car and hope you enjoy it as much as the rest of us. Happy driving!
Has anyone had problems with the service engine soon light suddenly coming on in the car? It seems to be coming and going. Any chance that there is something wrong with the sensors or computer?
Other than these two things, I have loved my car.
On another matter, has anyone had problems with wind noise? particularly from the rear door windows?
Finally, does anyone know of performance parts or accessories for this car? I'm at a loss for finding such items.
I read somewhere that the rear disc brakes are adjusted every time you apply the parking brake (similar to driving backwards and stopping with drum brakes).
The vibration in my Alero comes and goes. One day when I felt it, I decided to try something. With my finger on the release button, I pumped the parking brake up and down about 10 times (yes, with the car stopped). I noticed the vibration lessened. The next light I stopped at, I pumped it 10 more times. Now the vibration is a lot less than it was.
I'm starting to think that maybe the front brakes are working too hard and overheating. The overheating causes the rotors to warp.
Does this make any sense or an I crazy?
They immediately mentioned that a service bulletin had been issued, and they could replace the front rotors and pads with a newly design set. At first they stated that I would need to make another appointment to have them replaced, but then the senior service tech said a shipment had just arrived on Friday and because they did not have many appointments they could do the work today. That certainly sounded good to me.
I started feeling the warped rotor several thousand miles ago...I'll have to hope that I'm not asking for the same work to be done again before my warranty runs out.
Has anyone seen this bulletin? I'd love to get a glance at it!!
jjfalero, let us know if you get any different information from your dealer. And I hope people will post if they feel pulsing after replacing the brakes.
I'm a GM person. As I've said, my Cutlass Supreme has been great overall. I love the looks of the Alero and I'm sure it's a great car. But come on, GM, get you act together.
By the way -- my wife just turned 60,000 miles on her 1995 Grand Am (which features good old fashioned rear drum brakes) and we've had no such problems.
- '88-'93 W-body (Grand Prix, Lumina, Regal, Cutlass Supreme) the rear brakes stick because the caliper slider is made of dissimilar metals. Either the pins weld themselves together and/or to the caliper body, and with water, road salt, etc., the pins lock-up and stop sliding. As pointed out in a previous post, this results in rapid outer pad wear and if not caught, disc rotor wear too. A solution? There are kits available that replace the factory pins with stainless steel pins.
BTW, GM rear disc pads are mechanically adjusted by applying the parking brake. The piston is actuated via a thread rod via a lever that is connected to the cable. If you don't use your parking brake, the pads will not adjust. If you don't typically use the parking brake, I'd recommend using it once or twice per month, which should be sufficient. At replacement time, in order to install new pads, a keyed socket is needed to turn the piston on rod to make it retract into the piston bore.
