94 Bronco hesitation
I have a 94 Bronco that I have replaced the fuel
filter twice, fuel pump, spark plugs & wires, rotor
button, distributor cap, oxygen sensor, & cleaned
fuel intake & injectors. It has been to two Ford
dealerships and three independent garages; nothing
shows on the scanner. It starts fine but when
trying to acclerate it acts like it is runnig out
of gas sputtering and sounds like it is spitting
back through the intake. If I just let it adle in
the driveway, it feels like it si going dead. After
it has run so long it is fine. Does anybody have
any thoughts?
any thoughts?
When the tps sensor goes out, it can cause problems in multiple systems. Apparently, it isn't the first thing a mechanic would look for, either. Even Tommy, who is pretty sharp thought the symptoms on my car pointed to something else. He only tested the TPS in order to rule it out as a possible cause. He replaced it, and everything works fine.
Checkout an old entry in the Bronco owners section of this chat. Someone else seemed to have the same problem, and the tps sensor was to blame.
Good luck!
